i could study the manual but i'm betting some of you have these ideas easily and quickly. in the next 2-3 weeks i need to take the bird in for a:
1) fork oil change
2) brake fluid (front and rear) change
3) clutch fluid change
I'm wondering, aside from fluids, what parts i could buy myself that they'll tell me i need, in order to save some money.
like bushings? seals? washers that honda says to replace with these changes?
tia
should be nothing on the brakes and clutch change, the only thing on the forks maybe the O rings on the fork top nut, not worth bothering yourself unless its not a Honda dealer you are using and you want to make sure you have the right ones-just 2 one for each.(they do recommend you renew them each time you take the nuts off)
