oldbird Posted August 7, 2003 Posted August 7, 2003 For those of you running this combo,what settings are you using for the comp and rebound? I keep playing around with mine yet the rear still seems to be wallowing in the benders.My preload is at #6,my weight is at 188 lb plus gear. What say yee? Quote
RodeRash Posted August 7, 2003 Posted August 7, 2003 This is from an article that Carlos wrote about a year and a half ago. The rear damping settings are probably going to seem odd, but I swear this is what makes the compression and rebound even and about right. Rebound is 1/4 turn from full soft, and compression is 1/4 turn from full hard. This was double-checked by a very experienced shop owner and racer, so it's not just me going nuts. The rebound might be a *little* soft, but probably not even by 1/4 turn. I need to ride it a bit more. Having the compression right has made a huge difference in accelerating out of corners (or acceleration in general), and wheelies. Quote
oldbird Posted August 7, 2003 Author Posted August 7, 2003 That's one combo I have not tried but certainly will.Thanks. Quote
