birdie_xx Posted June 2, 2005 Posted June 2, 2005 I'm having some low state of my battery so I thought I'd check the prices on the replacement (this one is only 2 years old I think ) and I looked at Ron Ayers page. They list the YTX-12BS battery that I have and the YTZ-12S, which is twice as expensive ! :shock: Any idea what the difference is ? Are they equipped on the newer bikes ? Mine is the '99..... Cheers, Quote
birdie_xx Posted June 2, 2005 Author Posted June 2, 2005 Never mind, I found the answer.... http://www.yuasabatteries.com/search.asp Battery Family: Maintenance Free Battery Type: YTX12-BS Voltage: 12 Capacity: 10 Dimensions: 6" x 3.4375" x 5.125" Weight: 7.5lbs. Metric Dimensions: 150mm x 87mm x 130mm Metric Weight: 3.4kg Polarity: Acid Volume: 0.6 Amps: 1.2 C.C.A.: 180 Battery Family: YTZ Factory Activated, Maintenance Free Battery Type: YTZ12S Voltage: 12 Capacity: 11 Dimensions: 6" x 3 7/16" x 4 3/8" Weight: 8.1lbs. Metric Dimensions: 150mm x 87mm x 110mm Metric Weight: 3.7kg Polarity: Acid Volume: N/A Amps: 1.1 C.C.A.: 210 And the YTZ appeared in '01..... But is it twice as good ? Cheers, Quote
