jimmystartup Posted May 18, 2005 Posted May 18, 2005 Does anyone have a link to a good article or write-up on replacing brake lines? I'm comfortable bleeding brakes but have never completely replaced the lines. What is the process to ensure no air in the system? Quote
matey_peeps Posted May 18, 2005 Posted May 18, 2005 Don't worry, you'll get air in the system. The key is to properly bleed the system. Refer to your factory service manual. Read the section, re-read the section, get your tools out, re-read the section, and then bleed, while re-reading the section. Quote
jimmystartup Posted May 18, 2005 Author Posted May 18, 2005 Don't worry, you'll get air in the system.The key is to properly bleed the system. Refer to your factory service manual. Read the section, re-read the section, get your tools out, re-read the section, and then bleed, while re-reading the section. Got it! Do you have pictures of how I should do that? Quote
