george1 Posted June 13, 2003 Posted June 13, 2003 stopped for gas opened tank filled tank ready to leave key in igniton wont turn anyone have similar problem? Quote
kg4fku Posted June 13, 2003 Posted June 13, 2003 key wont turn in tank to release or key wont turn in ingnition switch? Quote
skybluebird Posted June 13, 2003 Posted June 13, 2003 ASSuming the key's not damaged ('cos it opened the tank), it's probably just a bit of muck in the lock preventing the key from locating properly. Put a few drops of light oil on the key, work it in and out of the lock a few times and wipe of any dirt that's stuck to the key. Flush the lock with a squirt of WD40 (GT-85 is even better, it leaves a Teflon coat), and away you go David Quote
SD Marc Posted June 13, 2003 Posted June 13, 2003 Any oil will attract dirt. You could use graphite. Quote
