scott s. Posted April 1, 2005 Posted April 1, 2005 where is the wind guard located in the upper? is it needed? if so how does it instal? also can you use a motorcycle floor jack on a xx seams it would be on the oil pan? thanks scott s. ps does anyone know about instaling a audiovox cruise control on a bird? Quote
Guest rockmeupto125 Posted April 1, 2005 Posted April 1, 2005 where is the wind guard located in the upper?is it needed? if so how does it instal? What the hell are you talking about? also can you use a motorcycle floor jack on a xx seams it would be on the oil pan? Depends on what you are doing with the bike. I wouldn't plan to lift it off the ground. If you are talking about a traditional "Harley" style floor jack, then NO...it won't work. ps does anyone know about instaling a audiovox cruise control on a bird? You need to do a little fabrication, but the instructions are pretty straightfoward, and it works a charm. I haven't done it, but others have, and I've seen the instructions....it doesn't look too bad if you've got a little mechanical skill. If, for instance, you can't reattach your watcband to your watch, then I'd look for someone else to install a cruise control. Quote
scott s. Posted April 1, 2005 Author Posted April 1, 2005 from what i can see in the service manual i think it's under the gages and the parts are listed in the microflich on the ron ayers web sight Quote
Guest rockmeupto125 Posted April 1, 2005 Posted April 1, 2005 Can I guess that yours is a carbed version? Forget about it. Quote
