I got my reg/rec!!!! Now I have a bunch of wires that I have to connect to the reg/rec without the plug. Can someone post pics of the end of their plug with colour references so I can make my own? I'd appreciate it! I'm soooooo close!
cool. I think I'll wire that up tomorrow. I might get my Dec ride in after all.
I'm in Canada, of course I don't have snow yet...Crap, can't keep a straight face. Yah, we had a shit load, probably whatever you had. Temps rising here, it's suppose to be +11 (that's 11 degrees over pure water freezing for those not following the other thread), or 51.8F today. I'm just working in the garage and waiting to see if my flat battery will take a charge, or if the rec/reg killed it. Otherwise I'll miss my Dec ride.
Ok, so it doesn't matter order of yellow, but there is still a red and a green. Can someone tell me the order it is on a OEM reg? If you look straight at it mounted with the plug facing up, which side is red? ie is it:
R G
Y Y Y
or
G R
Y Y Y
I'm soldering now, please let me know ASAP!
Tanks :]
Damn it, I'm blowing main fuses all over the place. Looks like the Y's do matter. I've run G and R then R and G, but still blow a fuse either way. Can someone confirm my colours? Both of the URL's offered don't show XX regs, I need an original for colour comparison.
looks like yellow with white strip. I can't make out the back row :cry:
I'll give that a shot today. Thanks! Can you confirm if those yellows are pure yellow, or do they differe from each other?
Thanks Joe! That did it. I must have double changed them around when I was testing the two ways. So I grounded, then grounded. Yahoooooo!!!
I gots myself a XX again!
