spEEdfrEEk Posted June 11, 2004 Posted June 11, 2004 CATEGORY: biology/metabolism TECHNICAL: **** SUMMARY: This is a fairly technical document that describes the different types of fuel the body will use under variable exercise conditions. Some of you out there, with a background in medicine, will probably really enjoy the detail -- for others it's a pretty hard read. As a result, I'm going to summarize some of the more important (and interesting) points. * ATP is the body's only energy source, everything is converted into ATP at some point * the order of fuels used by the body under intense exercise conditions is: ATP first, CP second, muscle glycogen, blood glucose, and liver glycogen. (glucose and glycogen are the body's sugar reserves). If all of those resources are exhausted, amino acids (proteins) are then converted to glucose * "feeling the burn" in a particular muscle implies that the glucose or stored glycogen are being metabolized at a rate too fast for the amount of oxygen present. This leads to lactic acid (causing the burn) which can be carried back to the liver where it can be re-converted into glucose. (so it's sort of a self feeding cycle) * carbohydrate loading can, in general, double the amount of glycogen stored in the muscle and liver. (and hence improve your stamina and performance) * adrenaline and noradrenaline are mostly responsible for the release of stored glycogen from the liver, and stored free fatty acids from adipose. Hence, without these two, you won't be able to tap your body fat for fuel. Fortunately, exercise increases both of them. * the body stores fats inside active muscle cells too. This intra-muscular triglyceride can also be tapped as an energy source, but they are hit less and less as the intensity and duration of an exercise increases. * Proteins and ketones can be used as exercise substrate (fuel) as well, but they only account for a small percentage, and aren't very efficient at the task. * Fats and triglycerides compose a significantly larger percentage of your body's stored energy reserves. ATP/CP can only last for a few seconds, and glucose/glycogen reserves can be depeleted in only a few hours with the right kind of effort. ------------------------------------------------------------- Basic Exercise Fuel Metabolism (1,2,3) Introduction The energy to fuel exercise can be generated from many different sources. Which source provides the majority of energy during exercise is dependent on a host of factors (such as availability, intensity/duration of exercise, etc) all of which will be discussed in later sections. To provide adequate background for upcoming sections, it will be helpful to discuss the basics of energy generation first as well as the basic pathways of fuel utilization during exercise. ATP: the master chemical ATP is the only substrate which the body can use for the generation of energy. Hence, all energy generating pathways have as their ultimate goal the generation of ATP. When a muscle contracts, ATP provides energy by being broken down to Adenosine Diphosphate (ADP) in the following reaction with the help of an enzyme called an ATPase. ATPase ATP ------------> ADP + Pi + energy (Note: Pi represents an inorganic phosphate molecule) Within each muscle, there is about 6 seconds worth of ATP stored which can be used for immediate energy. So for activity to continue past 6 seconds, ATP must be generated through various other reactions. The first of these of these is through what is called the creatine phosphate (CP) system. The creatine phosphate system Also stored in the muscle is a substance called Creatine Phosphate (CP). This provides a phosphate molecule to ADP to regenerate ATP so that muscular activity can continue. CP donates it's high energy Phosphate molecule to ADP to regenerate ATP via an enzyme called creatine kinase in the following reaction. Creatine ADP + CP --------------> ATP + Creatine Kinase There is enough stored CP in a normal muscle to provide energy for approximately the first 15-20 seconds of muscular activity at which time intramuscular CP is depleted (this provides the physiological basis for creatine loading which will be discussed in depth in the supplement section). The CP system operates in the absence of oxygen (it is anaerobic) and can provide energy very quickly during exercise. However, as with ATP, it's overall capacity to produce energy is low due to the limited amounts available. Collectively, stored ATP and CP are known as the ATP-CP or Phosphagen system. However, the total energy yield from the ATP-CP system is low due to the small amount of ATP and CP available in the muscle. As exercise duration exceeds 10-15 seconds, the ability of the phosphagen system to provide energy decreases and the body must rely on other fuel sources to generate ATP. One of these is the breakdown of glucose or glycogen (known as glycolysis or glycogenolysis respectively although the term glycolysis will be used here generally to refer to the breakdown of bodily carbohydrate stores). Glycogen is a storage form of glucose which is present in muscle and the liver. Glucose circulates in the bloodstream freely and can be taken up into muscles as needed. Glycolysis In a normal individual following a mixed diet, total muscle glycogen stores may comprise 250-350 total grams of carbohydrate with an additional 15 grams of carbohydrate circulating in the blood. There is an additional 90-110 grams of glycogen in the liver but it will be discussed separately below. During prolonged exercise at 75% of VO2 max to exhaustion (30-60 minutes or so), muscle glycogen stores will be totally depleted. With depletion of carbohydrate stores (generally accomplished with either exhaustive exercise or a carbohydrate free diet or some combination of the two) followed by several days of a high carbohydrate diet, muscle glycogen stores can be doubled to 700 grams of glycogen or more. During exercise, glycogen or glucose is broken down to provide ATP in the following reaction: glycolytic enzymes (Aerobic) Glucose/Glycogen ---------------------------> ATP + Pyruvate --------> Krebs cycle, liver, etc (Anaerobic) | / Lactate The breakdown of glucose or glycogen always initially results in the formation of ATP and pyruvate. But depending on the availability of oxygen (which is a function of exercise intensity), the pyruvate generated has one of two major metabolic fates. If there is not adequate oxygen present (as with high intensity exercise), glycolysis only provides 2-3 ATP molecules and the resulting pyruvate is converted to lactate. Lactate is an acid, causing the burning sensation felt in the muscles during exercise by lowering pH inside the muscle. This lowering of muscle pH inhibits glycolysis and may be one cause of fatigue during high intensity exercise. In the past, lactate was thought of as only a waste product of glycolysis that caused fatigue. However, it is now recognized that lactate is another useful fuel substrate both during and after exercise. Lactate can be used for energy by slow twitch muscle fibers (Type I) as well as by the heart. Alternately, lactate can diffuse into the bloodstream, travel to the liver, and be converted to glucose or glycogen through the process of gluconeogenesis (literally "the making of new glucose"). Additionally, following exercise, lactate can be regenerated to muscle glycogen which may have implications for individuals following a strict ketogenic diet as glycogen availability is the limiting factor in many types of exercise. Post-workout glycogen resynthesis from lactate will be discussed in a later section. This pathway of glycogen and glucose breakdown is known as fast or anaerobic glycolysis. If there is adequate oxygen present, glyocolysis produces 38-39 molecules of ATP and the resulting pyruvate is oxidized in the mitochondria to produce more energy through what is known as the Krebs Cycle. Alternately, the pyruvate may be released into the bloodstream where it travels to the liver and is converted to glucose (to be released back into the bloodstream) through the process of gluconeogensis. This pathway of glucose or glycogen degradation is known as slow or aerobic glycolysis. Liver glycogen In addition to muscle glycogen and freely circulating blood glucose, liver glycogen can also play a role in energy production during exercise. The liver stores up 110 grams of glycogen under normal conditions and, as with muscle glycogen, this can be increased with carbohydrate loading. In general, the liver is a storage depot of sorts for the body. Normally, the liver has a slow output of glucose (from breakdown of liver glycogen) into the bloodstream. In response to the release of adrenaline and noradrenaline during exercise (see section on hormonal reponse to exercise), liver glycogen breakdown and release into the bloodstream is greatly increased to maintain blood sugar levels. Additionally, glucagon and cortisol levels (which are also affected by exercise) further influence liver glycogen release into the bloodstream. Total depletion of liver glycogen will occur with 24 hours of total fasting but this may only take several hours during prolonged exercise (or much less for high intensity exercise). When, liver glycogen is depleted, blood glucose will also drop and the resulting hypoglycemia may be one cause of fatigue. Additionally, as it pertains to ketogenic dieters, the depletion of liver glycogen (and subsequent drop in blood glucose) below a certain level is necessary for the intiation of ketogenesis. It should be noted that total bodily glycogen and glucose stores can only provide approximately 1500 calories of useful energy (this can be doubled with carbohydrate loading) or enough to run approximately 15 miles. As this is still fairly limited energy wise, the body has several other sources of fuel that it can utilize during exercise. Metabolism of free fatty acids (FFA) and intramuscular triglyceride (TG) The body has two major stores of fats which can be used during exercise to provide energy. An 70 kg male with 12% bodyfat has approximately 70,000 calories of useable energy stored in bodyfat and an additional 1500 calories stored as intramuscular triglyceride. Assuming you could use 100% fat for fuel, this would be sufficient to run 720 miles. Even the leanest athlete with only 3 lbs. of bodyfat (containing approximately 1000 calories worth of useable energy) could run 100 miles if they were able to use fat for fuel. The question of why humans are unable to utilize 100% fat for fuel during activity is one that many researchers have asked themselves and is a topic that will be discussed in more detail later. Adipose tissue triglyceride metabolism As stated, bodily stores of adipose tissue contain approximately 70,000 calories of useable energy stored in the form of triglyceride (TG) which is the combination of three free fatty acids (FFA) and a glycerol molecule. But, in order for these triglycerides to be used by the muscle for fuel, they must go through the following steps: 1. Mobilization: in response to specific hormonal signals during exercise, adipose tissue TG is broken down within the cell to free fatty acids (FFA's) and glycerol (which is then released into the bloodstream) via the enzyme Hormone Sensitive Lipase (HSL). HSL activity is the ultimate determinant of lipid mobilization during exercise. Adrenaline and noradrenaline (which increase during exercise) stimulates HSL to release FFA into the bloodstream while insulin (which decreases during exercise and increases in response to increases in blood glucose) inhibits HSL activity and release of FFA to be used for energy. Insulin and the catecholamines (adrenaline and noradrenaline) are the only two factors which regulate FFA release from the fat cell (refs). 2. Tranport: FFA's enter the bloodstream where they bind to a fatty acid binding protein (FABP) to travel through the bloodstream where they are picked up by the muscle. 3. Uptake: The FFA-FABP complex binds at the muscle and is carried into the mitochondria for oxidation via the enzyme carntine palmityl transferase (CPT). *Additionally, once ketogenesis is established in the liver, circulating free fatty acids will be taken up into the liver and converted to ketones. The issue of post-exercise ketosis will be discussed in a later section.* 4. Beta-oxidation: in the mitochondria, the FFA is oxidized yielding ATP and acetyl-Coa. This acetyl-CoA enters the Krebs cycle to produce more usable energy. As will be discussed in a later section, each of the above four steps has been implicated as the rate limiting factor for the utilization of FFA during exercise. The beta-oxidation of FFA requires oxygen to occur (it is sometimes referred to as aerobic lipolysis (refs)) On average, one molecule of FFA will yield 129 ATP or more depending on the length of the FFA that is burned. Thus, compared to even aerobic glycolysis, fats provide a much greater energy yield. However, it should be noted that the oxidation of FFA requires more oxygen than the oxidation of glycogen or glucose. As will be discussed later, this has implications for ketogenic dieters. Intramuscular triglyceride (TG) metabolism As an additional source of energy, there are droplets of intramuscular triglyceride stored within the muscle proper. Depending on a host of factors (to be discussed later), this intramuscular TG will be oxidized in the same manner as blood borne free fatty acids. As they exist directly within the muscle fiber, they may exist as a more immediate source of energy during exercise. In addition to the use of glycogen/glucose and adipose and intramuscular TG, the body can also use protein and ketones for fuel during activity. Protein Under normal circumstances, protein is not used to a great degree during exercise. Under most circumstances, it may provide 5% or less of the total energy yield during exercise. However, with glycogen depletion, protein in the muscle can be used for fuel either by conversion to glucose in the liver (again, via gluconeogenesis) or by direct utilization by the working muscle. Ketones The oxidation of ketones for fuel is similar to that of free fatty acids and intramuscular triglyceride. Under certain conditions, ketones can enter the muscle where they are converted to acetyl-Coa and enter the Krebs cycle to produce energy. However, even under conditions of heavy ketosis, ketones rarely provide more than 7-8% of the total energy yield which is a relatively insignificant amount. A chart summarizing the amount of energy available from each fuel source appears below. Substrate Total bodily stores Useable energy ---------------------------------------------------------------------- Aerobic/Anaerobic ATP N/A 1.8 kcal Anaerobic CP N/A 8.4 kcal Anaerobic Glyocgen (muscle) 250 grams 1025 calories Depends Glycogen (liver) 110 grams 451 calories Depends Blood Glucose 15 grams 62 calories Depends Adipose tissue 7,800 grams 71,000 calories Aerobic Intramuscular TG 161 grams 1,465 calories Aerobic Ketones (!) Varies Varies Aerobic Protein (#) Varies 24,000 Note: this assumes a 70kg man with 30kg of muscle and 12% bodyfat. (!) Ketones rarely provide more than 7-8% of total energy yield even in highly ketotic individuals (#) Protein only provides 5-10% of total energy yield and is generally not considered as a major source of energy during exercise. Summary The body can produce energy for exercise by the breakdown of many different substrates. Generally speaking, fuel utilization can be broken into two general categories: Anaerobic energy production direct breakdown of ATP and CP stored within the muscle, which predominates during the first 15-20 seconds of exercise anaerobic glycolysis of muscle glycogen or blood glucose which predominates during the first 30-70 seconds or so of exercise Aerobic energy production aerobic glycolysis of glycogen or blood glucose beta oxidation of free fatty acids and intramuscular triglycerides oxidation of amino acids: which generally provides very little of the total energy during exercise oxidation of ketone bodies: which generally provides very little of the total energy during exercise The determination of which substrate provides energy during exercise depends on a host of factors including availability, the intensity/duration of exercise, the individual's training status and gender all of which will be discussed in upcoming sections. References: 1. "Physiology of Sport and Exercise" Jack H. Wilmore and David L. Costill. Human Kinetics Publishers 1994. 2. "Endurance in Sport" Ed. R.J. Shephard & P.-O. Astrand. Blackwell Scientific Publishers 1992. 3. "Exercise Physiology: Human Bioenergetics and it's applications" George A Brooks, Thomas D. Fahey, and Timothy P. White. Mayfield Publishing Company, 1996. Lyle McDonald, CSCS Some chemistry humor: "If you're not part of the solution, you're part of the precipitate." -- anonymous :cool: TJ :cool: Quote
