DRB NW WA State Posted June 9, 2004 Posted June 9, 2004 There’s usually controversy in this forum about the Avon AV45/46 combo. I’ve just replaced the AV46 rear, at 7.1K miles. The AV45 front has plenty of life left. Before commenting, it’s important to understand a few details to put the mileage into perspective. Total mileage: 7,100 (tire picked up a nail at about 6K, which was eventually plugged. I believe this tire had about 1,500 miles remaining, but the plug wasn’t holding well). - Rider weight: 175 lbs w/o gear. - Suspension: taut, aftermarket (Penske). - Bike: mostly-stock 1999, with Corbin hard bags - Inflation: faithfully kept 40-42 psi cold. - Type of riding: mostly super-slab commuting, with occasional twisties. - Other: no stunting or burnouts. - General riding style: medium-aggressive, with occasional trips to 100 mph+. - Location: Seattle, Washington State. Often wet roads, generally not too hot even in summer. Decent pavement. Rain riding performance: good. Predictable sliding when pushed. Very few scary moments not caused by the loose nut behind the bars. No complaints or close calls due to the tire. Sport performance: good. I didn’t push this tire hard too often, from a sporting perspective. When I did, it always held well and behaved predictably. Mileage: about what I expected, based on comments from the list. Stability: excellent. Summary: above-average experience. Probably too sporting a tire for my purposes (not the tire’s fault). I’ve switched back to the Bridgestone BT020 for this reason alone. Caveats: The AV46 worked better for me at higher inflation than I’m used to (40-42psi). Handling degraded noticeably at lower inflation. Hope this helps.
