matthend Posted June 1, 2011 Posted June 1, 2011 Need to tighten my chain. Cannot for the life of me remember the size of the rear axle nut on my 97. Anyone know off the top of their head? Quote
spicholy Posted June 1, 2011 Posted June 1, 2011 If I recall, 27mm. But, that is on my 99. Crescent wrench works in a pinch. Quote
Hobicus Posted June 1, 2011 Posted June 1, 2011 27mm, or 1.25 inches. Use a 6 sided socket, going from memory here the torque spec is 65 ft-lbs And the other side is a 22mm Quote
Pat830 Posted June 1, 2011 Posted June 1, 2011 69 ft lbs It just sticks in my mind for some reason. Quote
The Krypt Keeper Posted June 1, 2011 Posted June 1, 2011 69ft lbs 27mm nut 22mm axle head 8mm for adjuster bolts lefty loosey righty tighty Quote
matthend Posted June 1, 2011 Author Posted June 1, 2011 thanks all! I had actually tried the crescent wrench option, but could not get a good grip because of the lip that surrounds the bolt. Quote
spicholy Posted June 1, 2011 Posted June 1, 2011 Can't believe Hobi missed the 69 ft./lb. My world is now collapsing around me! Quote
EVLXX Posted June 2, 2011 Posted June 2, 2011 27mm, or 1.25 inches. Use a 6 sided socket, going from memory here the torque spec is 65 ft-lbs And the other side is a 22mm 27 mm = 1.06299 " or 1-1/16" Quote
Dragonslayer Posted June 2, 2011 Posted June 2, 2011 I do not own a 27 millimeter so I use a 1 1/8" , works fine for me. I just tighten until it feels just right:) Quote
Hobicus Posted June 3, 2011 Posted June 3, 2011 27mm, or 1.25 inches. Use a 6 sided socket, going from memory here the torque spec is 65 ft-lbs And the other side is a 22mm 27 mm = 1.06299 " or 1-1/16" Yep. I should have gone out to the garage and looked at the one I have. Sigh. Quote
