I'm hunting for a mechanical fuel pump for my 1984 Ford E250 Super Van (cargo version) with little luck, so far.
Details -- Original owner, 39K miles, 5.8L/351" H.O. 4V (Windsor), C6, Limited Slip 3:54, dual fuel tanks, factory upgraded suspension, GVW 8900 (that's important, it's over 8500 GVW).
More details/pics available if needed.
I'd like to find an appropriate OEM pump or its closest equivalent if possible.
The problem seems to be there are very few true OEM parts around for a 42 year-old classic truck/van.
The aftermarket has plenty of fuel pumps for the under 8500 GVW model (typically 5.8L/351" w/2bbl) but not the upgraded 8900 GVW (w/4bbl Holley) version. I can't find a definitive explanation for the differences between the two pumps (8500 GVW vs 8900 GVW) but I've been assured that internally they're different (likely pressure gradients--although my '84 OEM factory shop manual only lists specs like acceptable pressures in the 6-8psi range for all 1984 Ford truck/van V8 gas engines).
In '84 the 7.5L/460" 4V (same block) usually came with an electric pump as an assenbly of the in-tank sending unit. The shop manual references a mechanical pump with similar specs to the 8500 GVW, but that might be a unicorn (the 7.5L/460" was carbed with a different Holley, & mildly tuned for low-rev torque emphasis).
I've tried a mechanical fuel pump for the 8500 GVW. it's lasted about two years (less that 500 miles), but never really delivered as it should. It's now weakening to 3psi or less at idle--I suspect imminent failure.
A few years ago, I experimented with electric fuel pumps & one-way bypass valves, primarily to charge the fuel lines after the van had sat long enough for fuel to evaporate from the carb's float bowls & fuel lines--that didn't take too long with the crap-alcohol-laced-gas we've had to put up with. I finally settled on a Carter-style rotary vane auxiliary pump that's switched on/off from my dash that works fine in the interim. An adjustable pressure regulator/gauge near the electric pump and another gauge near the carb allows me to fine tune the pressure to the carb. It all works, but I'd really like to have the right OEM fuel pump, to keep it as original as possible. (Of course, I'll keep the auxiliary electric pump, just in case--always have a backup).
So, If anyone has a lead on an '84 5.8L/351" H.O. (8900+ GVW) mechanical fuel pump, please advise. I'd appreciate it.
Thanks, y'all . . .
It's always disappointing to find out some some relatively simple device has either completely gone from production or has disappeared from memory or even documentation.  I know the feeling.
I think you're over thinking it.
The pressure is probably the same between the two, the high GVW might have come with a higher volume pump which would only matter if you're on the gas hard for a while, and it probably doesn't actually matter.  Typically, fuel pumps flow way more than what's actually needed, but OEMs often spec a higher flow rate just to keep the large overhead they design into most systems.  Example: my '95 Mustang Cobra had a bigger pump than a GT even tho the GT pump is known to support much more HP than the Cobra made.  Same pressure and the engines were only about 20-30 HP different.  I added almost 200HP to that car on the stock pump and it still had more in it.
I looked on Oreilly online and they show a few options for the E-250.  The smallest cheapest one is rated for 25GPM minimum flow rate and up to 40GPH, 25 would support way more power than that engine makes.  The min/max is probably the flow rate at minimum and maximum pressure.  It shows the same pump for an E-350 which probably has a higher GVWR than your van.
Either you got a shitty pump that's failing early, something's wrong with the system, or maybe you created a problem with your electric pump and bypass stuff.  Throw a standard mechanical pump on it, they're only around $30.  If it doesn't make the rated pressure that means there's a problem somewhere in the system.
You have 3 PSI at idle, what does it drop to under a heavy load?  And have you been through a few 'standard' pumps or just the one?
I probably am overthinking it to some degree . . . okay, maybe a lot . . .
The original fuel pump lasted almost 35 years; the diaphragms finally succumbed, I suspect, to the 10% alcohol in gas.
I couldn't find a NOS/OEM replacement pump back then either; so, I opted for an aftermarket example (Airtex) that was cited as appropriate for 8900 GVW. That lasted just over four years. The subsequent search for the correct NOS/OEM pump was, once again, also in vain. The only aftermarket pumps I could then find were only rated for the 8500 GVW; anything rated for the 8900 GVW was always "not in stock" or "back ordered". So, I had to settle for a Carter rated for the 8500 GVW; that's what's on the van now. Initially, it gave a consistent 5-6psi, but with time has diminished to 2-3psi which doesn't appear to change under load.
The electric rotary vane pump is capable of 10psi (tested/verified) and rated up to 70gpm. The in-line pressure regulator can adjust from 1-7psi. This pump can more than meet the demand if/when the mechanical pump falters. With both pumps engaged, the adjusted pressure at the carb can be dialed in for consistent 5.5-6.5psi.
Consequently, I'm not stuck with a non-running van.
If/when the Carter mechanical pump ultimately fails, I can always dip back into the aftermarket for something sub-standard, but I'd much prefer having the correct OEM fuel pump, albeit a sourced replacement, working on the engine. I know that's probably a little OCD of me, but it is what it is. Maintaining this van as close to OEM original as pragmatically possible is really just another big-boy hobby for me (there, I've admitted it).
I've consulted with some friends (collectors) who face similar frustrations in searching for OEM parts, unfortunately none have been able to help.
So, I thought what the hell, we've got a very diverse group of folks on this site, so it can't hurt to ask around, can it?
Posted (edited)
I spent a stupid amount of time fixing a vacuum powered windshield wiper motor on a 1960 Cadilac that will never be driven in the rain because the guy gets a little nutty when anything on any of his cars doesn't work.  Just one of a billion things I've fixed to keep things original.  So I'll call you a 'tard for not being able to ignore it while fully understanding and respecting wanting to keep it original.
Edited by superhawk996
Hmph, guilty as charged, I guess . . . Among certain collectors, I understand this is something of a common OCD-like affliction. However, under some circumstances, I like to think of it as an underappreciated super-power that tends to have a positive effect upon intrinsic (and likely fiscal) value of the collectible (or at least the perception thereof).
Bottom line - if it makes you happy, it's worth it.
I've been set on not modding the "new" XX I got, not sure how much is obsessive-like or not.  I'm not sure what I'd do if I had to replace something like a fuel pump with an aftermarket part.  I think for me, it's purely about looking OEM externally.  I guess I've said exactly that.  Also, still waiting for an OEM owner's manual WITH COVER so that I can truly complete it.
The simple reality is that as our toys age, OEM/NOS parts only become more scarce, and the aftermarket becomes more of a resource. Unfortunately, even that alternative tends to diminish with time as more and more instances of inevitable compromise present themselves.   😮‍💨
Or as we age, try getting OEM parts...
Did you ask the seller if he has it?
LOL, yes, and he doesn't.
