QUOTE(BackStreet @ Jul 9 2009, 01:04 PM)
I'm fascinated. The only reason I change my own oil once a year is that it takes longer to go to the shop.
Any estimates of what has been spent so far in parts and hours of your time?
Just a round number guess would be fine.
Well I am running a sheet and keeping a running total, but, I am not too eager to hang someones laundry in public. I do have a lot of time in it, but only half or so in work.
But, just to give you the major things:
Getting it here turned out to be a bitch, and maybe a day of time,,,10 hours. I had gotten a huge break from Yellow freight, 75% off in a promotion phone call just before we were to send it. Great, lets set it up from his end with my info and company info. I had just shipped the same weight from the same area for 200. That make this cheap, right. More than 2 dozen phone calls and it still was more and was going on more than a month after delivery.
Tear down clean and inspect. Bout a day.
order parts another day.
deliver parts to machine shop another day. Why, well got to count and bag and box and load and deliver and unbox unbag and recount and spec work.( I normally unbag and count everything, but did not the new parts so they would not get lost, was a mistake) I don't do things like normal. My clearances and requirements are from 40 years of building race only engines and have a particullar way I want it done. Only a few will do it my way. And most don't have the tools that I require.
Three weeks later he had the tools to do the work, but, took another three weeks to get it done. Dozen calls.
Bore job done so go and get the block. 1/2 day
check bore to pistons and clearance and start filing and fitting rings to the bore is a good day work....wasted , see above, rings were the wrong set sent.
Valve job done, go and pickup, and start the port work. Takes two days to get it like I wanted. Clean and get ready to assemble.
See above. ( spend a good day looking for a valve spring height guage and spring pressure gauge to use on these heads. There aint one. no one make one and no one knows what to do about it. Now ain't that a kick in the nuts.) Tomek posted a cool tool to assemble valves on these motors, and was going to get it, but only good for 40 lb and lower. these are 60 seat presure. I could not find a spring compresor for a motocycle engine in all of this area.
So I make one. Another day down.
got another day in the rods and piston problem with assembly and machine work and hand work.
So what is that?
