Full Version: Brent's Motor rebuild
Pages: 1, 2, 3
cbrxxquad
QUOTE(jon haney @ Jul 29 2009, 01:41 AM) *
QUOTE(cbrxxquad @ Jul 28 2009, 04:54 PM) *
QUOTE(jon haney @ Jul 28 2009, 07:00 PM) *
I'm sure this is probably a dumb question, but aren't those little arrows on the top of the pistons supposed to be pointing towards the front of the motor?
You might want to take a closer look, ie blow them up, Jon, the marks on the pistons I put on there, so I would know. I for intake E for exhaust, which cylinder I want them to be in. The pistons came with no marks. The only way to know is that the exhaust valve cutout is a little closer to the edge of the piston. Go figure, I would have never thought that. Yes I had to ask.
I see it now. The arrow I was refering to is actually the number 4 that you stamped on it.
So, does it actually matter which way new pistons go in? The valve pockets looked the same on both sides to me.
jon haney
QUOTE(cbrxxquad @ Jul 29 2009, 05:35 AM) *
I'll take that as a yes.
cbrxxquad
QUOTE(jon haney @ Jul 29 2009, 02:49 PM) *
Mr.XX
QUOTE(cbrxxquad @ Jul 28 2009, 05:15 PM) *
so nobody noticed the oil hole was wrong in the rod,,,
I was just gonna say " The oil hole is the wrong way" on the thing-a ma-bob eusa_whistle.gif
great write up Stan .... makes me wanna go home and tear down my spare XX motor
cbrxxquad
found the link
QUOTE(tomek @ Jul 20 2009, 01:38 PM) *
I told you fricking people to do PAIR-crankcase vent mode two years ago but as a dumb immigrant I can get no respect here. evilgrin.gif .
http://www.cbr1100xx.org/forums/index.php?...526&hl=pair
Value of reducing/creating vacum in the crankcase has been known since 5 B.C.
XX4me
QUOTE(cbrxxquad @ Jul 29 2009, 01:01 PM) *
found the link
On mine I am creating a vacuum in the crankcase but I use the negative air pressure created in the compressor intake. I had to make an adapter to hold the air filter and tapped a hose barb through to the inside of the filter. The other end goes to the PCV fitting on top of the motor. Stopped all that pesky oil smoke at start up too.
Only problem I ran into was I needed a restrictor in the hose as it was pulling too much oil vapor into the compressor at full boost.
EVLXX
Nice....
I love watching your progress...
Makes me wish...
But, Oh now I remeber...
cbrxxquad
It's work,,,,, just not worth the pay..yeah, I am an idiot.
but,,,,anyway...
take that!!!
JB4XX
Need help installing those cams???
EVLXX
This is interesting.... Tell More, please.
QUOTE(eliXXir @ Aug 4 2009, 04:47 AM) *
Going to do the sleeve thing on the cylinders? (Like below)
cbrxxquad
That's where I am at, calculating cr. and the sleeve reinforcing. I don't have the equipment to properly do that type, but I have been considering another way to support it with a receiving groove o-ring. I could do that, if I had a mill....and it would help with the seal also.
Looking at that as a possibility in a few weeks,,, so depending on Brent's ability to pay for the additional work compared to the durability of it. I think he is going to have to make that decision as to the pressures and potential failures.
He has an idea that head gasket failures leave a lot to be desired and they are a direct result of the lack of cylinder support there.
With the valve to piston clearance now and a stock gasket used I wonder where we can go without the plate. We are close, closer than I was expecting without cutting the valve reliefs more. And a thicker head gasket will have a lot less support. I am leaning to a solid copper head gasket, and o-ring. Got any input in that area?
HANKSXXX
QUOTE(cbrxxquad @ Aug 4 2009, 09:23 AM) *
Give Cometic a call direct for their opinion.
Also, a lot of the import car guys are running a lot of boost and they sometimes do a hybrid gasket...o-ring in the block made out of copper with a MLS head gasket.
XX4me
Where are the coolant jackets?
On closer inspection I notice that this is not attached to the engine case.
Hmmm, Honda?
QUOTE(eliXXir @ Aug 4 2009, 12:47 AM) *
So, if this is going to be a 30 PSI turbo motor, what'd the CC values put your CR around?
What are you going to degree the cams to?
cbrxxquad
QUOTE(XX4me @ Aug 4 2009, 10:34 PM) *
Hmmm, Honda?
the top has a plate that goes inbetween the sleeves and the case and is 1/2" thick. and you can't see the rest of the block that is near you in the picture cut off.
It is the honda BB motor, but just the top of the case. So you can see all the way to the cardboard.
cbrxxquad
The numbers,,,
Bore 3.1875"
Stroke 2.23"
Rod length, 4.31"
piston dish 12cc
head gasket thickness, .060"
diameter 3.188
head 18cc
intake valve opens 40' abdc
7.52407: 1 static compression ratio
45.699 cc total displacement
effective stroke is 2.08"
dynamic compression ratio 6.75 ; 1
dynamic cranking psi 127.24 psi
dynamic boost CR relative to static CR cam timing altitude(1000 foot) and boost of 30 psi is,,,,,20.53:1
volume to pressure index is 25
HANKSXXX
Copper headgaskets also have a propensity for seeping, partially due to the fact that they need to be retorqued periodically...
As an aside, the MLS headgaskets prefer almost a polished finish on the mating surfaces and Cometic suggests they be assembled dry. I've been using spray Hylomar instead and have had no problems...then again, I'm not running that much boost...
Dean, when you said you went with "a know and proven solution", what was it?
Stan, thanks for all the pics and the updates..great thread and very interesting...Hank
BearXX
Damn.
I think i might not be the only one following the progress.
cbrxxquad
Ok got done with it, cams at 105 cl on the intake and 111 cl on the exhaust. Sealed up and ready to ship, other than boxing, or not. primed the oil system so it is going to have a qt of oil in it and the filter. went ahead and stuck some old plugs in it, and pluged all the lines. Made a line to connect the coolant lines and left it so might send it back. fittings are there but moved around just to seal and bagged the rest.
So if you want to have the guy come by, I will leave it like it is, Brent, but if your going to have me ship it, well going to have to build a box and attach to a pallet.
But, I am headed to the OK city area this weekend and I might be able to get it to the Chicago area, if that would help. Otherwise, I might be out during that time.
Kinda anticlimactic ain't it.
JB4XX
QUOTE(cbrxxquad @ Aug 10 2009, 07:03 PM) *
eusa_clap.gif eusa_clap.gif eusa_clap.gif eusa_clap.gif eusa_clap.gif eusa_clap.gif eusa_clap.gif eusa_clap.gif eusa_clap.gif eusa_clap.gif eusa_clap.gif eusa_clap.gif eusa_clap.gif
Amazing!
LMK if you need help with the cams on Dean's motor!
cbrxxquad
QUOTE(JB4XX @ Aug 10 2009, 10:33 PM) *
Amazing!
HANKSXXX
QUOTE(eliXXir @ Aug 11 2009, 07:08 AM) *
QUOTE(HANKSXXX @ Aug 5 2009, 01:39 PM) *
The sleeve shown in the picture. I had Elton do the 1st one (current one), and that 2nd one I bought at a "garage sale"..I've pushed almost 40 PSI of boost to the motor and never had a head gasket issue.
Gotcha...
I was thinking about the different headgaskets when I asked and hoped you had a trick setup...
cbrxxquad
crated and shipped
BackStreet
So, what is the final tally on hours and parts?
Is she in and running?
Red J
Sweet thread, Stan.
cbrxxquad
QUOTE(Red J @ Oct 1 2009, 12:13 AM) *
Sweet thread, Stan.
Well look who just pop in now and then. That just made it worth it. Great to see you again, I have missed you. Too cool. How have you been? Things all good?
Hey guys Jay posted!!!!
Redbird
'Sup, J?
brent
Ill be posting pictures with the install this weekend, might not have a dyno till next year when it starts warming up again...but will see evilgrin.gif
Red J
QUOTE(cbrxxquad @ Sep 30 2009, 08:22 PM) *
Doing well, sfarson and I went and bought VFRs. Fantastic bike, if a bit slow every so often. I suppose I'll buy an XX again, just not right now.
This thread brings back some memories for moi.
Hey, Tim. How's it going?
Brent, looks like your mill was in good hands, a turbo XX must be a force to respect. Kudos.
J.
Musclecar427
My claim to fame is rebuilding first gen v4 Honda engines to stock specs. This whole engine project is just plain mouth watering (in a horsepower kind of way). I have been looking at the pictures closely and trying to soak up all of the great information that is front of me. It's just amazing to me what you can do if you just put your mind to it.
Fast Eddy
Just re-read this thread. Great read.
I wish I could afford to Have Stan build me an XX motor.
Stan, how are you fixed for gloves? let me know if ya need more.
cbrxxquad
QUOTE(Fast Eddy @ Nov 17 2009, 06:52 PM) *
I wish I could afford to build you one too. Cause I should have gloves when I am gone. Should get you to make a box for me and them.LOL.
brent
I forgot to take unboxing pictures, Stan did an excellent job on the crate.. I was expecting some headache getting the engine back in since it was quite troublesome to take out..
but so far so good everything went smooth and im excited to see how much power she makes...
ROXX
Outstanding work Stan!
Wish I could be there to see/hear it run.
Music, sweet sweet music!
BearXX
QUOTE(brent @ Nov 23 2009, 03:47 AM) *
how much?
brent
QUOTE(BearXX @ Jun 28 2010, 07:54 PM) *
how much?
should be around 400hp @ 20lbs and pump gas..if i run race gas 35lbs should be over 550 but its completely pointless to run that much boost
i get her this weekend she is finally someone complete...possibly a video too
brent
QUOTE(eliXXir @ Jun 30 2010, 01:06 AM) *
QUOTE(brent @ Jun 29 2010, 11:31 PM) *
how much?
Hmm.. Those are some pretty stout numbers you're posting. Which turbo did you end up using?
65mm hybrid
Fonzie
QUOTE(redcam622 @ Jan 17 2009, 02:52 PM) *
This was my bike before Brent bought it from me. It went many times over 200 mph and many miles under heavy boost....most likely detonation happened when the fuel pump lost voltage for a second or 2 due to loose wireing...it is carbed not FI.
Late to the party I know, but since somebody already resurrected it.....
Isn't this the same XX that was in the International Motorcycle Show a couple years ago?
brent
QUOTE(Fonzie @ Jun 30 2010, 03:32 AM) *
if you are referring to the one at the javitz in 07 then yes
Fonzie
QUOTE(brent @ Jun 29 2010, 11:35 PM) *
Thought I recognized the pic back on page 1
BearXX
QUOTE(brent @ Jun 30 2010, 01:31 AM) *
how much?
Have you reinforced you joints, or are you expecting them to pop every time you hit the gas? icon_twisted.gif
brent
QUOTE(BearXX @ Jun 30 2010, 05:51 PM) *
how much?
JB Weld :)
more problems, the turbo was blowing smoke like a fog machine... very embarrassing
QUOTE(eliXXir @ Jun 30 2010, 12:20 PM) *
QUOTE(brent @ Jun 30 2010, 12:13 AM) *
how much?
65mm hybrid
And what cams/headwork have you had done? What RPM are you running to?
Ill have to have redcam chime in on this one, Running to 13500 RPM
Byrdman
Ouch. I have a sneaking suspicion that the wear on the turbo is well beyond a new impeller and bearings!
cbrxxquad
well I have done a few, now,,, and looks like it might need a little work. but might need some torque too. , Let me know if I can help....
brent
its odd, was still making plenty of boost just seemed to bogg down for a sec then the turbo would come on hard and blow the tire out.. and lots of smoke not from the tire
