Dynojet Powercommander has updated their site since this post. The link below will take you to the Powercommander download page where you can select individual maps to download, or download the self extracting zip file containing all the maps (m102-ALL).
Download Maps
In addition, here are some maps contributed by forum members.
Click to view attachment '03 full Yoshimura RS3, stock air filter, PCIII
Click to view attachment '99-'01 PCII with Scorpion slip-ons
Click to view attachment '03 PCIII with Two Brothers slip-ons, K&N filter. Map is tuned for economy on the bottom end and power on the top. Between 0-5000 RPM and less than 10% TPS the map works for economy. Anything above 5000RPM or above 10% TPS it map is setup for power.
The following is information from the Powercommander website and may not reflect the current state of availability of the respective maps.
Power Commander 2 Maps (1999-2002)
M102-000 - Zero Map
M102-001 - Completely stock bike
M102-002 - Completely stock bike with modified ignition curve. Use 93 octane or higher fuel
M102-003 - Full Micron "race only" exhaust
M102-004 - Full Micron "race only" exhaust with modified ignition curve. Use 93 octane or higher fuel
M102-005 - Full Akrapovic exhaust and stock air filter
M102-006 - Full Striker (Hiper Dimension EX) exhaust and stock air filter
M102-007 - Erion Racing full exhaust and stock air filter
M102-008 - Erion Racing full exhaust and stock air filter with modified ignition curve. Use 93 octane or higher fuel
M102-009 - Yoshimura RS3 full exhaust and stock or K&N air filter
M102-010 - Yoshimura RS3 full exhaust and stock or K&N air filter with modified ignition curve. Use 93 octane or higher fuel
European Models Only
M102-502 - European Model with Bos open slip-ons and stock or K&N air filter
M102-503 - European Model with Bos open slip-ons and stock or K&N air filter with modified ignition curve. Use 98 octane or higher fuel
M102-504 - European Model with Akrapovic full exhaust and stock or aftermarket air filter
M102-505 - European Model with Sidekick open slip-ons & Db killers with stock or aftermarket air filter
Power Commander 3 Maps (2002-2003)
M113-000 - Zero Map
M113-001 - Completely stock bike
M113-002 - Erion Racing slip-ons and stock or aftermarket air filter
M113-003 - Two Brothers Racing full exhaust and stock or aftermarket air filter
M113-004 - Erion Racing full exhaust and stock or aftermarket air filter
M113-005 - Two Brothers Racing slip-ons and stock or aftermarket air filter
M113-006 - Micron slip-ons and stock or aftermarket air filter
M113-501 - European model, completely stock bike with Dynojet O2 sensor eliminator kit
M113-502 - European model, Laser "Hot Cam" slip-ons, stock or aftermarket air filter with Dynojet O2 sensor eliminator kit
M113-503 - European model, Laser "Deep Tone" oval slip-ons, stock or aftermarket air filter with Dynojet O2 sensor eliminator kit
M113-504 - European model, BOS ECE slip-ons, stock or aftermarket air filter with Dynojet O2 sensor eliminator kit
M113-505 - European "German" model, BOS ECE slip-ons (without catalysts), stock or aftermarket air filter with Dynojet O2 sensor eliminator kit
M113-506 - European "German" model, stock exhaust (with catalytic converters), stock or aftermarket air filter with Dynojet O2 sensor eliminator kit
M113-507 - European model, Two Brothers slip-ons, stock or aftermarket air filter with Dynojet O2 sensor eliminator kit
M113-508 - European model, Quill T3 Power Flow slip-ons, stock or aftermarket air filter with Dynojet O2 sensor eliminator kit
M113-509 - European model, Akrapovic full exhaust, stock or aftermarket air filter with Dynojet O2 sensor eliminator kit
M113-510 - European model, Leo Vince open slip-ons, stock or aftermarket air filter with Dynojet O2 sensor eliminator kit
M113-511 - European model, Yoshimura RS3 full exhaust, stock or aftermarket air filter with Dynojet O2 sensor eliminator kit
* Also, Skull has pointed out that the California models are the same as the European models.
