Not to step in but.... weight is a terible way to gauge your progress. My first comment would be to throw away your scale. I would have jumped on your little bandwagon earlier but I don't really want to loose much weight...just drop my bodyfat from 12% to 6%. A scale is bad because you could fluctuate 2-5 lbs in any given time during the day just in water weight.
Use a tape measure (soft), a picture, how your clothes fit, a bodyfat test to see how you are progressing...not the scale.
Make sure you are drinking .66 times your bodyweight in ounces of water per day. THis will do several things....flush your body of toxins if you have increased your protein intake, you will retain less water weight, you will burn more fat, and you will be more hydrated.
To loose bodyfat...you need to eat right (5-6 times a day to increase your metabolism and eat the right foods), do cardiovascular exercise to burn calories, and have resistive training to build muscle.
Note to women....you don't have to worry about looking like a muscle chick if you lift weights...a woman has to workout 3 times as hard as a man becuase you don't produce Testoserone. Lifting weights will actually make you more firm without necessarily making you weight less. Remember, muscle weighs more than fat.
THink of it this way...it's easy to gain fat...but fat burn no calories and it's hard to loose. Where ever you gained the fat first...that's where it will come off last. It takes time to build quality muscle but you can burn like 50 calories per pound when you are sitting in a chair. But if you don't keep working out, you can also loose the muscle pretty easy. No.... muscle gained does not change into fat when you quit working out. It's just easier to gain fat.
And you need to expend 3500 calories during exercise to burn just 1 lb of fat over and above what you are eating. You have to eat to loose and eat to gain...it's a crazy cycle.
I can post more on how to eat...what food to eat...how to figure out how many calories to eat...etc if you all would like.
