black black bird Posted April 26, 2004 Posted April 26, 2004 Hey just went on a trip it was fine but many bumpy road and i also hit a bad hump when i got back i realize that the handle bar turns in ward in the direction of slow corners plus when i release my hans from the handle bar at 100 knmh the bike moves straight but the handle bars are rattleing why is this is this because of a spoilt stearing cone or bearing? there are no unuals noise from the bike could it be the air pressure another qusetion my rear braek makes and auwful rubbing noise from time to time despite changing new bads it my discs gone fuck??? thanks so much for the help people.. Quote
xxxbirdxxx Posted April 26, 2004 Posted April 26, 2004 The "WOBBLE". It is most likley your head bearings. I am going to be changing mine very soon because of the same reason. very common, no worries dude! ? 2) Is the time to time when your bike has sat for a day or 2 and goes away after riding? If so, it is just surfes rust and again no worries. If not then you might want to change your brake fluid to a full synthedic like I did and make sure none of your calipers are hanging up? I have seen some BBXX ware the pads uneven and that is do to the slides and pistons hanging up. RR them and re-grease. Hope this helps. Quote
