When driving on the freeway or city streets and there are several consecutive bumps in the road or the road is just rough, my bike jumps or slows down due to not keeping the throttle constant. Would adjusting the throttle help or bringing in my Heli-bars help keep the throttle more constant?
Thanks for any help...
steve
Relaxing, especially in your arms, would help more than anything. Can never hurt to ajust the freeplay out of the throttle, though.
You're obviously moving the throttle a lot, and you have the cables tensioned while riding, anyway, so adjustment will probably do very little for you.
I adjusted mine a lot tighter, but only for off-idle transitions, and throttle response on downshifting.
Redbird is right about relaxing your arms while riding, and if you're doing a lot of freeway riding, you may want to consider a Throttlemeister.
Is it pretty hard to install the Throttlemeister? My wife and I are planning a trip to Sedona this May and that would be nice to have...
2 things helped me:
1) throttlerocker (ultimately taught be to relax also
2) power commander (much of the twitchiness was tuned out with the new map)
but if you want a non-mod answer, it's "relaxing"
Nope, it's pretty simple. Ten minute job if all goes smoothly. It'll come with instructions and everything you need, including a tool to pull out the right side bar weight.
I think you may be right on holding on too tight and being a little too stiff. I will try a long ride tomorrow and see how it turns out. I am also going to look into the Throttlemeister...
Thanks for the reply's!!!
steve
