Furious Posted August 2, 2005 Posted August 2, 2005 I just installed a PCIII on my Bird and I have to say that it does make a very noticable difference. When I took it out for a test run the other night I think I fell a little more in love with the bike. I DID notice that the Bird seemed to run hotter in town when I was observing the speed limit a little more closely. Has anyone else noticed an increase in temperature or was my Bird angry cause I was making it go soo sloooow? Thanks, Furious Quote
matey_peeps Posted August 2, 2005 Posted August 2, 2005 Didja end up leaning it out on the bottom end? That could result in more heat. However, it has been FUCKING HOT lately. Quote
Furious Posted August 2, 2005 Author Posted August 2, 2005 I just ran with the preloaded program for now, haven't gotten around to exploring it too much. Only change to the bike is JRed's PV removal kit. Quote
Ronnie Posted August 2, 2005 Posted August 2, 2005 I just installed a PCIII on my Bird and I have to say that it does make a very noticable difference. When I took it out for a test run the other night I think I fell a little more in love with the bike.I DID notice that the Bird seemed to run hotter in town when I was observing the speed limit a little more closely. Has anyone else noticed an increase in temperature or was my Bird angry cause I was making it go soo sloooow? Thanks, Furious Great thats what I need a hotter running XX..haven't installed mine yet but was wishing for a cooler running bird. Quote
Redbird Posted August 2, 2005 Posted August 2, 2005 Great thats what I need a hotter running XX..haven't installed mine yet but was wishing for a cooler running bird. That'll be entirely dependant on what map you run. Leaner= hotter, richer= cooler. Most maps I've seen do lean out the bottom end, most notably at smaller throttle openings. Quote
Ronnie Posted August 3, 2005 Posted August 3, 2005 I asked Power Commander about this, here is their reply It's possible temp may raise slightly, the bike is quite rich and we are removing fuel to improve performance. Combined with a hotter climate, this is normal. There is no danger of harming the bike. If it was lean enough to cause damage, it would run terribly. It is recommend that you use a similar map for your exhaust, like M113-006, this is slightly richer and should help lower temp. Thanks, Manny Hauswirth Technical and Race Support Dynojet Research Quote
