Ordered a throttlemeister setup for the newer model helibars. This same setup will work on the stock clipons as well.
Well, my helis are the older model. Had to pull the throttle side bar off and drill out the spot welds that hold the insert in place and it still took 20 min. of snatching to get that damn bugger out.
Good news is that once the insert is removed, the TM insert works perfectly....so the older/newer helibars and the stock bars all appear to have the same i.d. bars....just a much bigger pain to get the inserts out of older model helis.
The spot welds on the older helis are in the same location as the holes on the stock bars that the metal prong on the inserts fit into....stock inserts can be inserted into the helis.
Just usless info for your perusal.
Porter
