Travlnman Posted June 7, 2003 Posted June 7, 2003 Well I installed a universal power plate [ http://www.electricalconnection.com/power%...ion/pp-univ.JPG ] the other day so I can run(and fuse) all my accessories to one location. every thing works great except my turn signals blink twice as fast, wassup wit dat? do I need better ground for my accessories? Quote
scubajohn Posted June 7, 2003 Posted June 7, 2003 Most of the time you will have to add inline resistors to get the blinking to calm down. As far as what size sorry no clue. Quote
scubajohn Posted June 7, 2003 Posted June 7, 2003 Wow they copied Warchilds Light mounts err well almost same Idea. Quote
Travlnman Posted June 7, 2003 Author Posted June 7, 2003 $44.95 Nope.... the relay taps into the positive side of the headlight so when you hit the starter it shuts down the accessories(momentarily) so the starter has maximum juice. Quote
kg4fku Posted June 7, 2003 Posted June 7, 2003 are your turn signals coming off this box? if not then the only reason your blinkers should even flash faster is if a bulb is blown or not properly seated. you should have one blinker in the rear and one in the front. try that and give us an update. Quote
Travlnman Posted June 7, 2003 Author Posted June 7, 2003 I don't have the front turn signal/mirrors on the bike right now so that may be the problem, I wanted to see if every thing worked before I put the body work back on. Will update soon. Quote
