rhubarbray Posted October 10, 2009 Share Posted October 10, 2009 Who`s got the right hand euro housing? I`ve just installed the HIDs and would like to have the option of turning the light off while starting. My housing has 7 wires in a red 9 plug connector and into the same on the subharness. Is the euro one 9 wires in a 9 wire plug? Or do you have to run extra wires? Quote Link to comment Share on other sites More sharing options...
Redbird Posted October 10, 2009 Share Posted October 10, 2009 Who`s got the right hand euro housing? I`ve just installed the HIDs and would like to have the option of turning the light off while starting. My housing has 7 wires in a red 9 plug connector and into the same on the subharness. Is the euro one 9 wires in a 9 wire plug? Or do you have to run extra wires? If you can find one it's plug and play, no extra work involved, but watch the harness length coming off the switch. Different years were different lengths. You can work around that, but it can be a pain. In the meantime, you can just press the starter button before you tun the key and the lights will only fire once per start, after the motor has fired and the button has been released. Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted October 10, 2009 Share Posted October 10, 2009 I have the euro switch, and did a write up on here a couple of years ago about how I modified it. Mine has three settings.... all lights on, all lights on except headlamp, and then ALL lights off, aka "stealth mode." Quote Link to comment Share on other sites More sharing options...
XXNUTZ Posted August 28, 2014 Share Posted August 28, 2014 Hello OrganDonor, I just got one of these UK RH switch blocks and would like to see that write up...could you post it up again or shoot it to me?...I would appreciate it...cheers. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted September 9, 2014 Share Posted September 9, 2014 (edited) In the meantime, you can just press the starter button before you tun the key and the lights will only fire once per start, after the motor has fired and the button has been released. Be aware that If it's a FI bike it may take a little more cranking since the fuel pump won't be able to prime the system before cranking. If you only did a low beam HID the other option is to go to high before starting then switch back. Please post which light kit you got and your impression of it. Edited September 9, 2014 by superhawk996 Quote Link to comment Share on other sites More sharing options...
Chewtoy Posted September 29, 2014 Share Posted September 29, 2014 Hello OrganDonor, I just got one of these UK RH switch blocks and would like to see that write up...could you post it up again or shoot it to me?...I would appreciate it...cheers. +1 to that, I have the Euro switch, but can't turn off the running lights. Would like to go stealth (as stealth as a red bird can be) Gracias. Quote Link to comment Share on other sites More sharing options...
