runninn Posted September 8, 2014 Share Posted September 8, 2014 What soft tiedowns do you use to transport the bird? It's been so long I forget...I am off to trackday soon and am looking for good soft tiedowns or an equivalent. thks Quote Link to comment Share on other sites More sharing options...
DBLXX Posted September 8, 2014 Share Posted September 8, 2014 I use dental floss or connected tampon strings. Quote Link to comment Share on other sites More sharing options...
Mikey Posted September 8, 2014 Share Posted September 8, 2014 I use a canyon dancer type tie down. Works. It's tad hard on the grips and mine are so old they are starting to dissolve anyway (the grips I mean). The angle is bad, it rubs against the plastic if your tie downs aren't far enough apart. Quote Link to comment Share on other sites More sharing options...
DBLXX Posted September 8, 2014 Share Posted September 8, 2014 (edited) Seriously though....I used SOFT tie downs around the LOWER triple tree and a couple hook on the the back passanger pegs. Edited September 8, 2014 by Dave_K Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted September 8, 2014 Share Posted September 8, 2014 I've used a long tie down and wrap it around the grips. Do it right and it comes off and clears the plastics. Put it on as snug as you can and tighten...lifting the bike vertical OFF of its kickstand. Leave kickstand down in case it starts to loosen. Quote Link to comment Share on other sites More sharing options...
jon haney Posted September 8, 2014 Share Posted September 8, 2014 I have tie-downs with the big hooks on each end. The hook will fit over the lower triple clamp, and since it is steel and can't be seen easily, I don't worry about scratches. You do have to be careful with the angle of the strap so it doesn't rub the leading edge of the fairing or the fender. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted September 8, 2014 Share Posted September 8, 2014 (edited) Canyon Dancer with PVC pipe over the grips and a second set of straps from the rear peg holders. I also used a home made front wheel chock. Edited September 9, 2014 by blackhawkxx Quote Link to comment Share on other sites More sharing options...
EVLXX Posted September 8, 2014 Share Posted September 8, 2014 I use a set of Modified Canyon Dancers Quote Link to comment Share on other sites More sharing options...
DBLXX Posted September 8, 2014 Share Posted September 8, 2014 Canyon Dancer with PVC pipe over the grips and a second set of straps from the rear peg holders. Exactly what I used to do most of the time. Quote Link to comment Share on other sites More sharing options...
xrated Posted September 8, 2014 Share Posted September 8, 2014 Buy yourself a Baxley wheel chock, not a cheap knock-off. Roll the bike into the Baxley and flip the lock arm and pin it. Next, use two tie down straps and attach them to the passenger pegs and pull down and forward with them. Done! I've hauled both track bikes this way for the last 7 years and have NEVER had an issue. I know the Bird is heavier than my 600RR's but I've also hauled my ST1300 this same way and it outweighs the Bird by a couple hundred pounds. Quote Link to comment Share on other sites More sharing options...
brianmacza Posted September 9, 2014 Share Posted September 9, 2014 Seriously though....I used SOFT tie downs around the LOWER triple tree and a couple hook on the the back passanger pegs. And here we have Dave's BDSM kit on display Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted September 9, 2014 Share Posted September 9, 2014 +1,000,000 on a front wheel chock. Even one from Hazard Fraught tools will do fine for keeping the bike upright and stable. Working with tie-down becomes a snap with that done. Quote Link to comment Share on other sites More sharing options...
jon haney Posted September 9, 2014 Share Posted September 9, 2014 (edited) Buy yourself a Baxley wheel chock, not a cheap knock-off. Roll the bike into the Baxley and flip the lock arm and pin it. Next, use two tie down straps and attach them to the passenger pegs and pull down and forward with them. Done! I've hauled both track bikes this way for the last 7 years and have NEVER had an issue. I know the Bird is heavier than my 600RR's but I've also hauled my ST1300 this same way and it outweighs the Bird by a couple hundred pounds. THIS! I have one of these in my trailer. I once forgot to put the tie-downs on the drag-bike. More than 200 miles later, bike hadn't moved. There wasn't even a scratch on the wall 3" away from the left clip-on. Trailer even has a torsion axle and is kinda bouncey. A Baxley is a bargain at $250. Edited September 9, 2014 by jon haney Quote Link to comment Share on other sites More sharing options...
CBRXX Posted September 9, 2014 Share Posted September 9, 2014 I think last time I hauled the bird was maybe to NEXXT in 2004, and maybe once before that. Used the canyon dancer on the bars for the straps in the front, and to the back peg brackets. In a pickup the the stake pocket tie downs are high enough I dont think it really rubbed the fairing. Maybe put a few layers of blue masking tape on there if you have an issue. I think if tie down points are low, might be better from the lower triple. Beware the front fender doesn't hit anything. I think I had to have a block of wood in front to keep from contacting the front bed wall of my truck. Since then, I bought a Condor front chock stand but have never used it. I recall the guy doing a demo to sell them. The bike was in the stand, and he was pulling the bike so hard to the side it looked like the tire was going to peel off the rim, but the bike would not come out of the stand. A buddy of mine used to load his race bike into a van with one of them and no tie downs. Quote Link to comment Share on other sites More sharing options...
xrated Posted September 9, 2014 Share Posted September 9, 2014 I wouldn't haul a bike in a Baxley without the rearend being strapped down and pulled forward, at least not on purpose, but it would probably stay just where I put it.....they are that good. I've got two of them in the trailer obviously, as I haul two track bikes, one is mine the other is my wife's bike. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted September 10, 2014 Share Posted September 10, 2014 While checking out the Baxley, I was surprised to find them at Wal Mart. http://www.walmart.com/ip/29389472?wmlspartner=wlpa&adid=22222222227020073645&wl0=&wl1=g&wl2=c&wl3=52349462295&wl4=&wl5=pla&wl6=79448028375&veh=sem Quote Link to comment Share on other sites More sharing options...
Desert Goat Herder Posted September 10, 2014 Share Posted September 10, 2014 While checking out the Baxley, I was surprised to find them at Wal Mart. http://www.walmart.com/ip/29389472?wmlspartner=wlpa&adid=22222222227020073645&wl0=&wl1=g&wl2=c&wl3=52349462295&wl4=&wl5=pla&wl6=79448028375&veh=sem If you look it's from discount ramps. Wally world sells a lot of things from their web site that other companys actually ship to you. Quote Link to comment Share on other sites More sharing options...
jon haney Posted September 10, 2014 Share Posted September 10, 2014 While checking out the Baxley, I was surprised to find them at Wal Mart. http://www.walmart.com/ip/29389472?wmlspartner=wlpa&adid=22222222227020073645&wl0=&wl1=g&wl2=c&wl3=52349462295&wl4=&wl5=pla&wl6=79448028375&veh=sem That's definitely a bargain. Quote Link to comment Share on other sites More sharing options...
xrated Posted September 10, 2014 Share Posted September 10, 2014 That is a great price. I paid $199/each when I bought mine in 2007. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted September 11, 2014 Share Posted September 11, 2014 http://www.cbr1100xx.org/forums/uploads/monthly_05_2011/post-1680-1305335915.jpg http://www.cbr1100xx.org/forums/index.php?showtopic=82646&hl=ugly-trailer Quote Link to comment Share on other sites More sharing options...
RodeRash Posted September 11, 2014 Share Posted September 11, 2014 Quote Link to comment Share on other sites More sharing options...
John01XX Posted September 11, 2014 Share Posted September 11, 2014 1858_1a.jpg Hobie has one of those that is old, worn out and rode hard and put away wet! 1 Quote Link to comment Share on other sites More sharing options...
XXBirdSlapper Posted September 12, 2014 Share Posted September 12, 2014 Lay the bike down and pile your gear on top of it. Its goin NOWHERE. HEY, BIRD! Where you goin? NOWHERE! Quote Link to comment Share on other sites More sharing options...
xrated Posted September 12, 2014 Share Posted September 12, 2014 Lay the bike down and pile your gear on top of it. Its goin NOWHERE. HEY, BIRD! Where you goin? NOWHERE! Lay the bike down and pile XXBird Slapper UNDER it. Its goin NOWHERE..............Fixed that for ya. 1 Quote Link to comment Share on other sites More sharing options...
