Blackbirds
silverbird1100
16 hours ago, XXitanium said:
I was almost wondering if this is Poida's 'stralia bike?
no way.whoever owns that looks like they do some serious touring.it looks to me either russia or the stans.be good to find out if they have a blog somewhere.
nick sanders  rode an r1 around the world in 19 days back in 2005
Around The World In 19 Days… | Continental Motorcycle UK ...
Only would have taken 16 on a blackbird
  • Like 1
"1999 HONDA CBR1100XX BLACKBIRD. CAME OUT OF THE GARAGE WHERE IT HAS BEEN FOR SEVERAL YEARS. BOTH TIRES ARE NEW, BATTERY IS NEW, FUEL TANK CLEANED AND FUEL PUMP AND FILTER REPLACED, FUEL INJECTORS CLEANED AND FLOW TESTED, NEW K&N AIR FILTER, NEW CLUTCH DISC KIT AND FRESH MOBILE1 OIL CHANGE. BIKE IS A 1999 SO THERE ARE SOME DINGS AND SCUFFS ON PLASTIC BUT IS IN GREAT SHAPE. COMES WITH NEW EXHAUST THATS NEVER INSTALLED, POWER COMANDER NEVER INSTALLED AND CORBIN TRUNK SEAT IN ADDITION TO FACTORY SEAT. EMAIL WITH QUESTIONS OR MORE PICS REQUEST THANK YOU FOR LOOKING"
is there $3,000 in extras?
4 hours ago, silverbird1100 said:
Owner claims 451lbs with 15l of fuel
I think I need his scale for my bathroom.
Not buying the 451.  If it had CF wheels, fairings (including tank), and sub-frame, it might be close.  Pretty sure thats a TI pipe.
Edited by jon haney
Front fork (and lower yoke) from CBR900RR '98
Front fork upper yoke made upon my own design
Front mudguard from CBR900RR'98
Rear carbonfiber mudguard
Front wheel from CBR600F '96
Rear wheel from CBR900RR '96
Rear swingarm from CBR900RR '98
FG Shock absorber (longer than stock)
Central stand removal
Front brake disks by Alth (310mm Ø)
Rear brake disk by Alth (220mm Ø)
6 pistons (and 6 pads) front brake calipers by ISR
Read brake caliper from CBR900RR '98
Carbonfiber handlebars with handmade ergal 7075 clamps (my own design)
Pazzo Racing levers
Front brake radial pump Brembo 19x20
Rear brake pump from CBR900RR '98
Clutch pump from VTR100SP
Supersporx ergal sprocket (Z +2)
Footrests by my own design, made in Ergal 7075
Rear subframe coming from CBR900RR '96 (modified to fit main XX frame)
Rear cowl from CBR900RR '96 (mono seat)
Akrapovic 4-1 full exhaust
Carbonfiber exhaust bracket
Flywheel lightened by 300 gr
Airbox modified (increased volume and reduced internal turbulences)
K&N airfilter
PowerCommander unit
Air snorkels by my own design, made in 1060 aluminium
Aluminium and silicon cooling piping
Carbonfiber tank cap
Li-Ion battery (-3 kgs !!)
Ergal and titanium bolts
He said this is how he did it and yeah, he's full of it. The wheel's aren't even aftermarket
Mainly by removing the central stand (4.5 kg) and by replacing the rear sub-chassis (in carbonsteel) with the Fireblade unit in aluminium
Moreover, the wheels are significantly lighter, as well as the Li-Ion battery (with the battery only I saved 3kg!!)
The braking system is much lighter
The swingarm also is lighter
The handlebars are in carbonfiber, as well as the tank cap
The stock fork yokes are in steel, very heavy; the fireblade fork yoke is in aluminium. The top yoke is superlight
The ignition key holder (with the antitheft system) has been totally removed
The titanium Akra exhaust in the place of the stock unit saves a lot of weight
The passenger footrests are off
Etc etc etc...
Edited by silverbird1100
