sandman Posted October 9, 2020 Share Posted October 9, 2020 (edited) I almost got stranded today on my '01 Redbird. No running issues before whatsoever, parked after 20 minute ride, tried to start and heard it starving for fuel, then nothing. Cranked over strongly- good battery. I checked the fuses, lifted the fuel tank and started checking connections. I moved the connections on the fuel pump, and it then started. Runs normally since then, so it was corrosion at that connection and not the fuel pump I assume. My XX almost 20 years old- should I CorrosionX all the connectors, or do something better? Edited October 9, 2020 by sandman Quote Link to comment Share on other sites More sharing options...
OMG Posted October 9, 2020 Share Posted October 9, 2020 Yes - every connector and every ground. Quote Link to comment Share on other sites More sharing options...
redxxrdr Posted October 9, 2020 Share Posted October 9, 2020 40 minutes ago, OMG said: Yes - every connector and every ground. You said that it sounded like it was running dry. My 01, 50 plus K miles developed a clogged filter. I replaces it, and had no more running or starting problems. 1 Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted October 9, 2020 Share Posted October 9, 2020 (edited) Before messing with the connector did you notice if the pump was running? If so, did it sound normal? I always paid attention to mine but I know some, maybe most, ignore it. First few times I started the '97 I had a brief "oh shit" moment. The connector doesn't look like anything's wrong, but it might have something I don't see. And it's not a switch connector, just fuel pump connector. I can't think of a reason to not hit it with CorrosionX, but if it does have corrosion/burns/looseness that should be taken care of first. The spray might help a minor problem, but isn't a proper cure and it probably won't last if the problem isn't properly repaired. Edited October 9, 2020 by superhawk996 Quote Link to comment Share on other sites More sharing options...
sandman Posted October 9, 2020 Author Share Posted October 9, 2020 Come to think of it, I do not remember hearing the fuel pump humming when I attempted starting. No clear signs of corrosion and no burns at the fuel pump connector, but jiggling it worked and got me home. There were no signs of corrosion either on the dreaded factory test plug when that left me stranded, so I'm still thinking that this is the issue at the fuel pump connector. I hoped someone else had experienced and recognized the same problem. I will go through every connector and ground as OMG has suggested. I appreciate the suggestions, advice, and shared experience- I need to regain trust and confidence in my bird. 1 Quote Link to comment Share on other sites More sharing options...
OMG Posted October 11, 2020 Share Posted October 11, 2020 Speaking of confidence, two years ago I tore down the bird to add a few things electrical and went thru all connections. Yesterday I was fueling up a guy on a harley rolled over and asked about my bike, I politely said his bike was beautiful. He thanked me and then went on a rant that it is a 2020 and has a wobble at 75 that the dealer won't acknowledge. I realized that I don't think of anything wrong or suspect about this 21 year old, completely reliable at any speed, every ride. Also was thinking as I stopped along the river that one of the useful mods I did was to weld a larger pad to the sidestand. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted October 11, 2020 Share Posted October 11, 2020 6 hours ago, OMG said: one of the useful mods I did was to weld a larger pad to the sidestand. I've considered that a few times despite the rarity of needing it. Quote Link to comment Share on other sites More sharing options...
OMG Posted October 11, 2020 Share Posted October 11, 2020 37 minutes ago, superhawk996 said: 7 hours ago, OMG said: I've considered that a few times despite the rarity of needing it. Only takes once, I have scratches and a cracked faring to prove it. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted October 11, 2020 Share Posted October 11, 2020 First time it happened to me was on asphalt. My GF & I rode to a cabin in Big Bear and parked on the driveway, seemed good & hard. A couple hours later both of our bikes were in a hard lean, mine over hers. They didn't reach the ground or touch each other as I recall, but getting my VF1000R up with her Ninja under it without damaging anything was an absolute bitch. Second time was my SuperHawk in the dirt right next to the driveway. My dirt is close to concrete hardness so I had no worries. It rained overnight, but not enough to concern me. Well, the runoff just happened to be concentrated and aimed at my side stand. The bike fell towards my GF's truck, didn't hit it, but landed partly under it in a way that the truck couldn't be moved out of the way. The truck was also on dirt so I couldn't move it over with a floor jack. Getting the bike up without adding damage was an absolute bitch. Quote Link to comment Share on other sites More sharing options...
RXX Posted October 14, 2020 Share Posted October 14, 2020 On 10/11/2020 at 4:46 AM, OMG said: Speaking of confidence........ I realized that I don't think of anything wrong or suspect about this 21 year old, completely reliable at any speed, every ride. My bird was built in October 1998 and I just completed a 5,000 mile ride with no expectations of any issues. So yeah, they are great bikes. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted October 14, 2020 Share Posted October 14, 2020 33 minutes ago, RXX said: My bird was built in October 1998 and I just completed a 5,000 mile ride with no expectations of any issues. So yeah, they are great bikes. Pretty fly for a old guy. 😉 Quote Link to comment Share on other sites More sharing options...
Tom Posted October 23, 2020 Share Posted October 23, 2020 Noob question fellas - is there a way to check the wires/installation on these bikes, given that they're 20+ year machines now for the most part? Other than visual "corroded plug" inspection, how would one test if a wire is going bad? Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted October 23, 2020 Share Posted October 23, 2020 Wires rarely go bad without visible signs of damage. They rarely corrode in the middle, it starts at a connection. They rarely have heat damage without damaging the insulation. If a wire is smashed or otherwise physically damaged it could break or corrode, but there will generally be obvious signs of damage. The sneakiest damage that can lead to corrosion is a pinhole, most commonly caused by someone probing a wire with a tester. I've owned and worked on stuff WAY older than these bikes and don't recall finding a damaged wire that didn't show signs of damage, don't worry about it. The sneakiest wire problem on these is the test connector because it's a connector that's hidden inside the wire harness. There's also a few connections in the front cowl that can corrode and are hard to get to. 1 Quote Link to comment Share on other sites More sharing options...
tomek Posted October 23, 2020 Share Posted October 23, 2020 I had issue with nephew's Subaru Legacy, I dunno, about 10 years ago. No power going to ecu. Everything tested fine with multimeter. It was definitely puzzling but after receiving piece of advise from mikesail I went thru critical wires with load probe. Basically couple wires hooked up to 55 w halogen bulb. Sure enough, main power line to ecu had internal corrosion. Quote Link to comment Share on other sites More sharing options...
Tom Posted October 25, 2020 Share Posted October 25, 2020 Thanks for the advice hawk! One more question though, last year my mechanic did the regular service on the bike and mentioned that one of the main loom connectors, not sure which one but one of the "main ones" is going bad, I think he was saying that it started to show signs of corrosion, or something akin to it - not sure. Either way I will strip the bike down during the winter so I'll have a better look - but lets say one of those main loom plugs is showing signs of toast - is it possible to fix it without buying the loom from ebay or, yikes - Honda Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted October 25, 2020 Share Posted October 25, 2020 Any connector can be fixed. In some cases I'll eliminate the connector and just splice the wires together, most connectors are there for ease of assembly and never need to be disconnected again. Or you can clean/tighten/replace the terminals as needed. Corrosion at a connector can travel up the wire. If you strip the insulation and the wire is discolored you want to keep cutting 'till you reach clean shiny copper. Sometimes that's impossible without cutting the harness, at that point, if it's not too shitty, I'll treat it with CorrosionX or something similar and let it ride. If you seal up the wire any continuing corrosion should be stopped or damn near stopped. If the connector has been wet recently then trapped water could keep eating away at the wire after your repair, just something to think about when you start to plan the repair. 1 Quote Link to comment Share on other sites More sharing options...
sandman Posted November 11, 2020 Author Share Posted November 11, 2020 (edited) Update and not good- got stranded with no functioning fuel pump. No warning, just go/no go failure. Thought wrongly that corrosion at the connector plug was the issue, only temporary. I suspected fuel pump failure, but tested voltage at the brown plug- no voltage to the pump! Hot wired fuel pump- it works. Fuse panel checked out. Where and what should I go back from the connector and check? Edited November 11, 2020 by sandman Quote Link to comment Share on other sites More sharing options...
fizzy Posted November 11, 2020 Share Posted November 11, 2020 1. Check fuel pump relay and connector(s) 2. Continuity of individual wires in fuel pump circuit. This circuit includes the ECM, so unplug 2 large connectors to it and clean/inspect + look for any broken wires. Also, make sure ECM is strapped down. There should be a very large O ring over it but can use bungy cord/wire ties etc. 3. Last but not least, you may need to do the "loom fix". In short, there is a junction block hidden under the loom tape that corrodes and causes intermittent/unusual electrical maladies. Not that hard if you are handy with a soldering iron. Note: Disconnect the battery before messing with the ECM 1 Quote Link to comment Share on other sites More sharing options...
sandman Posted November 14, 2020 Author Share Posted November 14, 2020 (edited) I appreciate the helpful suggestions. Been watching lots of youtubes, seems to occur quite a bit on CBR600RR's. So many different things can cause it, I will have to go through and test every possible component and connection. Relays, fuses, bank angle sensor, stop switch, side stand cutout, one guy even found hidden wire corrosion inside a fuel pump connector wiring sheath. I did the loom fix a few years ago when that left me stranded. Does anybody know if USA spec ignition switches have the 12v-9v diode underneath? Seems to come up often bad as a fuel pump no go cause. My riding season is definitely over. Edited November 15, 2020 by sandman Quote Link to comment Share on other sites More sharing options...
fizzy Posted November 15, 2020 Share Posted November 15, 2020 sandman, The trigger for the fuel pump relay is a ground (I think its a ground) signal from the ECM on 4th wire counting from the LHS. Wire is listed as Br/Bl. This trigger signal may be dead. Only reason I mention this is because this exact problem has come up a few times on another blackbird forum. If everything else checks out OK, then solution is either another ECM or hot wire the bad ground trigger signal with a relay thru the stop/start switch. This will allow the pump to run ALL the time the ignition and stop switch is on, for normal operation of the bike. If you resort to this remember the ECM will no longer be able to shut off the pump in the event of trouble. As far as the diode goes, it is not on the wiring diagram. I am not aware of one. First for me. PS: I am assuming when you turn on ignition...........no fuel pump sound at all. Quote Link to comment Share on other sites More sharing options...
sandman Posted November 18, 2020 Author Share Posted November 18, 2020 (edited) Thanks for the suggestions and insights. Yes, with ignition on there's no fuel pump sound at all, but I hot wired it and it's functional. I mentioned the first time it almost failed previously- I jiggled the fuel pump connector switch and that worked for a few weeks/couple of rides, thought it was corrosion there- I don't know if this is a real clue pointing to the actual fault or not. OK then on the lack of a diode underneath the ignition switch- I wanted to ask if it applied to our bikes, as it comes up often as a cause of no fuel pump function on other CBR models of the same age. After checking other possible components, definitely will look closely at ECM and look for threads about this on the other board. Hesitant to hotwiring it, though- if I do, are you saying to add an additional relay through the start stop switch to the ECM? Edited November 18, 2020 by sandman Quote Link to comment Share on other sites More sharing options...
fizzy Posted November 18, 2020 Share Posted November 18, 2020 No, not exactly. Disconnect or cut the Br/Bl wire (that goes to the ECM) near the pump relay end and attach a new one that goes from said pump relay to the new relay. Take the ECM out of the fuel pump loop altogether. I have not done this procedure myself, so please double check against the wiring diagram and your own troubleshooting. This would be after you have eliminated all other faults. Quote Link to comment Share on other sites More sharing options...
sandman Posted December 1, 2020 Author Share Posted December 1, 2020 Update: after reading numerous CBR "no fuel pump prime" threads here and elsewhere, one caught my attention. Decided to first have my no cranking problems, always Battery Tended battery load tested. At two different places. Bad cell. New one is on the way- can't wait to see if this was the cause. Will update either way so that others might benefit. 1 Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted December 1, 2020 Share Posted December 1, 2020 If the bike still cranked with the bad battery but the fuel pump wouldn't run, the battery wasn't the cause of the fuel pump issue. A new battery might make the fuel pump run because the extra power could overcome whatever the actual problem is, but it's not the solution. Quote Link to comment Share on other sites More sharing options...
sandman Posted December 1, 2020 Author Share Posted December 1, 2020 Thank you for the response. Yes, it did crank but did not give fuel pump prime. If what you suggest is correct in this case, I'm not sure where to look next. Thought that a bad battery could have been the cause. Quote Link to comment Share on other sites More sharing options...
