Biker Bling
Biker bling are a UK company who provide blot sets in stainless steel.  I bought the complete blackbird fairing kit from them and also a mixed bag of M5/M6 pan head bolts for my garage bolt stock.  The bolts are well manufactured and have the same drilled design as the standard bolts from Honda.  In fact, the only difference I can see is the material, the standard items being made of steel that is not stainless.
The guys who run it are very helpful, I first enquired after these in June and they had no stock, they were hoping for stock in August but it actually took until late september for the sets to arrive.  I would happily use these guys again for bolts.
  • 1 month later...
On 9/29/2020 at 4:26 PM, SwampNut said:
Cost?
I didn't know our bolts weren't stainless until I got a bike that had been in CA humidity and all the bolts had mildly damaged finish.  In AZ they stay shiny.
What's in the tube?
GB £50 plus postage
The tube contains grease, some of the bolts go into stainless nuts and unless grease is used there is a small possibilty they can sieze together
Edited by JaBr
On 9/29/2020 at 8:29 PM, SwampNut said:
Probably the standard zinc on all other bolts?  Later today I'm going to have to compare a few bolts and see.  I was also planning to see if I can use XX Frankenbolts on the KTM for bungee points.
The biker bling site shows a comparative picture of their stainless vs manufacturer original.
  • 1 year later...
On 9/29/2020 at 8:26 AM, SwampNut said:
Cost?
What's in the tube?
If they're not stainless they fooled me.
doesn't apply much to our blackbirds as they're mostly aluminum but, i was warned not to use stainless bolts in steel as it sets up a galvanic reaction between the 2 different metals.
i'm learning a bit of grease or anti-seize can help minimize this.
  • 9 months later...
I believe the reaction between stainless and aluminum is much stronger than between stainless and steel.
  • 2 months later...
  • 1 month later...
