nomadicdread Posted January 23, 2020 Share Posted January 23, 2020 Is it possible, has anyone changed one of the Fi model digital cluster to a Fi analog cluster? In my quest, it appears that I come to a pass often going from ‘98 to ‘03. Most often I’m seeing ‘03 in black which is the color I prefer but, they have the digital cluster that I don’t care for. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted January 23, 2020 Share Posted January 23, 2020 I can’t say yes or no, but I considered the reverse for my ‘99. In theory, if the “pins” of a digital dash match those of an analog dash, I would expect it to work. I did something similar on my old S-10 pickup...put in an improved gauge cluster from a higher trim model. Only modification was that I had to replace the oil pressure sensor as I went from a warning light to a needle gauge. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted January 23, 2020 Share Posted January 23, 2020 Just ride it, you'll probably get over it. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted January 23, 2020 Share Posted January 23, 2020 That's something to consider. I was really attached to the analog and was kinda bummed about loosing it when I got the '01. Then got over it. But now I'm back to analog and altho I like it, it didn't stand out as a huge bonus. From recollection, they swap easily and the only issue is that one has an FI light and the other a side stand light. But I don't remember if it's a straight plug & play or not. I'm almost certain I read about it here somewhere. Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted January 23, 2020 Author Share Posted January 23, 2020 2 hours ago, SwampNut said: Just ride it, you'll probably get over it. In the past I moved forward with a vehicle purchase based on that sentiment. Three years later when people ask if I'm still liking it my response is, "If I would have waited a bit longer, I would have got something else." It's been 19 years since they changed the cluster and I don't think I'll start taking a shine to it any time soon. Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted January 23, 2020 Share Posted January 23, 2020 You can certainly change the cluster. You need a different wiring connection to the loom and I believe the temp sensor. '99 and '00 were analog gauges...not a big deal. The FI/kickstand light are the same, just different lettering/color on the cluster cover. Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted January 23, 2020 Author Share Posted January 23, 2020 4 hours ago, rockmeupto125 said: You can certainly change the cluster. You need a different wiring connection to the loom and I believe the temp sensor. '99 and '00 were analog gauges...not a big deal. The FI/kickstand light are the same, just different lettering/color on the cluster cover. Have you seen this or have an image of this different wiring connection? Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted January 24, 2020 Share Posted January 24, 2020 I've seen this wiring connection a few times. The front sub harness on the analog clocks is 32102-MAT-A00. It has two plugs that fit into the analog dash. The front sub Harness on the digital clocks is 32101-MAT-A20. It has a single plug that fits into the digital dash. I never took pictures of them. When I plug a digital dash into my '99, the temp gauge doesn't work. As I recall, it has to be switched out to the later sensor. I've never plugged an analog dash into my 2001, so I can't say that it works, but there's no reason to suspect it wouldn't, except for the temperature sensor. Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted January 25, 2020 Author Share Posted January 25, 2020 Thanks for the input. The more I ask and learn, I’m leaning toward just sticking with a ‘99. Changing the cluster sounds like a dicey proposition to me. Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted March 4, 2020 Author Share Posted March 4, 2020 On 1/23/2020 at 4:29 PM, rockmeupto125 said: I've seen this wiring connection a few times. The front sub harness on the analog clocks is 32102-MAT-A00. It has two plugs that fit into the analog dash. The front sub Harness on the digital clocks is 32101-MAT-A20. It has a single plug that fits into the digital dash. I never took pictures of them. When I plug a digital dash into my '99, the temp gauge doesn't work. As I recall, it has to be switched out to the later sensor. I've never plugged an analog dash into my 2001, so I can't say that it works, but there's no reason to suspect it wouldn't, except for the temperature sensor. I see what you’re saying now. I wonder if a person would have to make changes to the plug that connects the sub assembly. For the temp sensor that’s mentioned, is that a engine temp sensor or air temp sensor? Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted March 4, 2020 Share Posted March 4, 2020 Its a straight plug in. You need the engine temperature sensor from a digital XX. Some installs spoke of a resistor someplace, but I can't help you there, sorry. Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted March 4, 2020 Author Share Posted March 4, 2020 (edited) 19 minutes ago, rockmeupto125 said: Its a straight plug in. You need the engine temperature sensor from a digital XX. Some installs spoke of a resistor someplace, but I can't help you there, sorry. So, if I had a ‘01 or newer bike I’d have the engine temp sensor, and that installs into the ‘00 or older cluster? Edited March 4, 2020 by nomadicdread My thumbs Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted March 4, 2020 Share Posted March 4, 2020 Find a parts bike, didja? The entire cluster and the cable plugged into it swaps over. The temp sensor is in the engine head. And if you just plug the later cluster into the harness, everything works except the temp gauge. Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted March 4, 2020 Author Share Posted March 4, 2020 4 minutes ago, rockmeupto125 said: Find a parts bike, didja? The entire cluster and the cable plugged into it swaps over. The temp sensor is in the engine head. And if you just plug the later cluster into the harness, everything works except the temp gauge. lol not quite. I am seriously considering an '03 and have eyes on a decently priced '99-'00 instrument cluster and the sub-wiring assembly. In theory, I could use a '99-'00 temp sensor? Or are they different plugs? Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted March 4, 2020 Author Share Posted March 4, 2020 I've got the same conversation going on at the other forum https://www.cbrxx.com/threads/change-cluster-from-digital-to-analog.49673/#post-639529 The mention of the analog using two sensors, one for temp and another to start the fan has me going deeper down the rabbit hole of figuring this out. Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted March 4, 2020 Author Share Posted March 4, 2020 A post on going from analog to digital. https://www.cbrxx.com/threads/dash-upgrade-99-to-05.9447/ After reading it, I wonder if I just need the cluster, temp sending unit, wiring sub assembly, and thermo switch from a '99-'00 to put into an '03 Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted March 5, 2020 Share Posted March 5, 2020 AFAIK the fan is controlled using a temp switch in the radiator up to about '00, and later ones are triggered by the ECU. If the ECU and gauge use the same sensor then changing the sensor to an early one is likely to fuck with the fan activation and tuning. If that sensor is only for the gauge and the ECU uses a different temp. sensor then all should be fine. Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted March 5, 2020 Author Share Posted March 5, 2020 1 hour ago, superhawk996 said: AFAIK the fan is controlled using a temp switch in the radiator up to about '00, and later ones are triggered by the ECU. If the ECU and gauge use the same sensor then changing the sensor to an early one is likely to fuck with the fan activation and tuning. If that sensor is only for the gauge and the ECU uses a different temp. sensor then all should be fine. That's just about what this other guy is saying https://www.cbrxx.com/threads/change-cluster-from-digital-to-analog.49673/ Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted March 5, 2020 Share Posted March 5, 2020 I know some people are just prejudiced against carbs, and I kinda get it, but they haven't given me any issues. Other than the cold start/warm up I can't tell the difference. I went from a '97, to '01, and now back to '97. With big elevation & temperature changes the FI should do better so that could be more of an issue for some. Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted March 5, 2020 Author Share Posted March 5, 2020 One thing I'm confused out is the "temp sensor". Is everyone talking about the water temp sensor? Or is it some other sensor? Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted March 5, 2020 Share Posted March 5, 2020 Yup, coolant temp. Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted March 5, 2020 Author Share Posted March 5, 2020 Just now, superhawk996 said: Yup, coolant temp. OK. So then I'm trying to understand, how have the correct water temp sensor for whatever dash is used, and having the correct thermo switch would cause a problem for fan triggering. Here's a quote from the other forum. Quote So looking at that thread. Its possible to reverse the directions and put the analog dash in. If you change out the FI bulb in the analog dash to an LED bulb you may have that issue fixed. The temp sensor is going to be your issue as it's going to read wrong on the gauge. If you switch it to fix the gauge then your going to alter your fan actuation point. These circuits are one and the same on the digital and separate on the analog. That makes the switch over to digital the easier of the 2. To go the other way your going to have to accept a misreading temp gauge or find a way to recalibrate it (if it even has the correct range). So that explains what Rockme was saying about the temp gauge not working, I think. So then the question would be, how does a temp gauge get calibrated? Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted March 5, 2020 Share Posted March 5, 2020 On a Carbie/early EFI the sensor is only for the gauge, the fan is triggered by the switch in the radiator, so swapping the analog sensor for a digital dash sensor has no impact on the bike. If the EFI bike is using the sensor for the ECU then swapping in the analog dash the sensor will fuck with it. If the digital dash temp sensor is lower resistance than the analog dash sensor then you might be able leave the digital dash sensor in and put a resistor in line with the analog dash temp sensor so that the ECU sees the right temp and the gauge sees the right temp for it to work normally, or at least in a relatively good range where it'll be useful. Or put in a separate temp gauge. Or just ignore the temp gauge since they *never* overheat. Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted March 5, 2020 Author Share Posted March 5, 2020 14 hours ago, rockmeupto125 said: Find a parts bike, didja? The entire cluster and the cable plugged into it swaps over. The temp sensor is in the engine head. And if you just plug the later cluster into the harness, everything works except the temp gauge. 14 hours ago, rockmeupto125 said: Find a parts bike, didja? The entire cluster and the cable plugged into it swaps over. The temp sensor is in the engine head. And if you just plug the later cluster into the harness, everything works except the temp gauge. Been racking my brain all day with posts trying to understand the things going on the background. I think I'm starting to understand now and was likely chasing my tail today due to a number of other factors. So, is there a way to calibrate the temp gauge? Quote Link to comment Share on other sites More sharing options...
nomadicdread Posted March 5, 2020 Author Share Posted March 5, 2020 3 minutes ago, superhawk996 said: On a Carbie/early EFI the sensor is only for the gauge, the fan is triggered by the switch in the radiator, so swapping the analog sensor for a digital dash sensor has no impact on the bike. If the EFI bike is using the sensor for the ECU then swapping in the analog dash the sensor will fuck with it. If the digital dash temp sensor is lower resistance than the analog dash sensor then you might be able leave the digital dash sensor in and put a resistor in line with the analog dash temp sensor so that the ECU sees the right temp and the gauge sees the right temp for it to work normally, or at least in a relatively good range where it'll be useful. Or put in a separate temp gauge. Or just ignore the temp gauge since they *never* overheat. The digital dash sensor? I'm starting to understand what's going but, which digital dash sensor are you talking about possibly leaving in? Quote Link to comment Share on other sites More sharing options...
