Biometrix
Question for you electrician types
I'm running a 6/3 line from my main panel to a new 60 amp sub panel in a detached garage. I would also like to pull an RG6 and Cat 6 cable (both shielded). It's going in buried conduit so would you use
1-1/2" or 2" conduit?
Share this post
Link to post
I'd probably go with 2". But check with code, some jurisdictions won't allow high and low voltage wires in the same conduit.
Share this post
Link to post
Are the devices on both ends compatible with shielded Ethernet cable?  Are you aware of the grounding requirements?
Share this post
Link to post
The jurisdiction in question will not be privy to this particular project. I was thinking 2" also but didn't want to over-do it. The 2" conduit body boxes just seem huge.
Yes, the Cat 6 is for a PoE camera. The others are all run with shielded Cat 6. If you mean grounding of the sub panel, also yes...it will need a separate ground at the garage. If you mean some other type of grounding then I am at a loss and would welcome your advice.
Share this post
Link to post
3 hours ago, SwampNut said:
No, I mean how will you ground the STP cable.
Well fuck! See, this is what happens when you blindly rely on the advice of others. One of my field techs (who normally is pretty sharp) is the guy who installed my PoE camera system and strongly suggested the shielded Cat6. Clearly based on a quick Google search it appears this was unnecessary and I know now it's not grounded at all. I think I'll have him climb up in my attic again now and replace the shielded to the other cameras with regular Cat 6 as penance. Thanks for the heads up on that.
Share this post
Link to post
I'm no expert on STP since I use it once a decade, but from memory...
STP is rarely needed.  If you use it, there's a special male connector.  That goes into a device with a special female connector that grounds it.  You ground both ends IF they have a common ground, only one end if you don't.  Ask me how much money I've made replacing shit when people grounded a cable on two ends with separate grounds, and lightning induced voltage into one end (even though the building wasn't hit, it was just in the air).  An attic should never have STP, that's crazy.  Oh, and in outdoor applications you ALSO need a surge arrestor with its own ground.  If the device is PoE, then obviously you can ground both ends.
My last run of it was almost ten years ago, to go around 450 feet (yes, out of spec, it worked) under a boat dock.  The far end was specifically ground tested to be sure it was equivalent to the head end, and we grounded both.
Again, no expert on STP, but I think if you have existing ungrounded runs of it, you're going to be fine.  I don't think there's a need to remove it.
Share this post
Link to post
Interesting.  I was told that you use the same ground as the house for your outbuildings.  My garage and my shop are both wired to the house ground.
Share this post
Link to post
My unattached garage has a separate ground.
Share this post
Link to post
I'm just repeating what the electrician told me. He's putting in the sub panel and making the connection to the main panel and pounding in the new 8' ground rod. I'm just putting in the conduit and pulling the wire he specified plus the two extra that I want. He's the one who said either 1.5" or 2" conduit but it was my call. Anyhow...I went with 2".
Share this post
Link to post
I believe this varies by area, due to soil differences and things like that.  I'm no expert, but have heard differing things in different parts of the country.
Share this post
Link to post
