Sign in to follow this
XXitanium
Conformal coatings
I'm trying  a "CorrosionX" on my drowned F250 GEM module.
Have any of you heard of this stuff?
I was told it it used by NASA and the US Navy.
Share this post
Link to post
I think Carlos used that on an RC boat that drowned and some electronic thing 'died'.  He sprayed it and it came back.
Share this post
Link to post
A quote from Swampy.
Quote
CorrosionX.  Miracle stuff.  You guys will thank me.  Get it.
  I have marked it to buy some day but haven't done it yet.
Edited by blackhawkxx
Share this post
Link to post
Ok..couple of things in conformal coatings of PCB's.
1)  You can only keep the PCB as dry as it is when you coat it.  The PCB absorbs moisture and needs to be baked at about 150 - 200 F for min of 3 hrs to really cook the moisture out of the board.  Coating without baking..will trap moisture and can help to cause failure..not prevent it.
2)  Anti-static.  Ground the board and yourself when spraying.  You can't use too much, but make sure you layer and coat it like a you would paint a car...but liberal use is just fine.
3)  Dry.  Let it really dry.  Another baking is just fine.
In my days manufacturing industrial sensors..they used Humiseal quite a bit and that is where I learned the above practices.  Full potting is the best option..but Humiseal is pretty good.
https://m.skygeek.com/humiseal-1a33-humiseal-1a33-aerosol-conformal-coating-11-5-oz-can.html?utm_source=googlebase&utm_medium=shoppingengine&utm_content=humiseal-1a33-humiseal-1a33-aerosol-conformal-coating-11-5-oz-can&utm_campaign=froogle&gclid=Cj0KCQjwyYHaBRDvARIsAHkAXcsKR7F8ignRfRqM2xc_TB7f1J5vcZfvg5kDXX5g1L9Xed1w1IQxeRMaAijfEALw_wcB
Share this post
Link to post
...hmmm, I let the board get tacky. I saturated the wireways and slathered them in dielectric grease. My thought was that water would have a hard time getting in if it had to push grease out of the way.
It started and we put about 40 miles on it. I think I'll do the windshield / seal - and see if I can get six months more out of it.
This stuff resembles WD-40. It did talk about drying in the instructions though.
I suppose I trapped propellents and solvnts in there...
Share this post
Link to post
1 hour ago, blackhawkxx said:
I wonder if it can be used on aluminum to prevent storage corrosion?
....I was thinking the same thing....
Share this post
Link to post
This shit is pretty amazing.  I will never be without it.  The incident Oscar was talking about was with my sea planes and the home-built boats where I wanted to use non-marine electronics.  This makes them totally reject water.  Submerging the electronics does nothing to them.  I use it on things like fence hinges and latches, or anything that's outside and needs corrosion protection that seems to last "forever."  Years I guess.  It's a thick foamy oily coating.  I've used it on anything on the boat that looked like it was hinting at oxidizing.
Oh, there are two types, I use the red.  I can't remember what was different about the blue label.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
