CALCXX
Spacers Carrozzeria wheels
FTM raised a topic I have long forgotten about. Carrozzeria wheels. I have a used set off of Hobi's XX I never successfully mounted.
I don't have the spacers and the confidence to figure it out.
If you have a 96-98XX with Carrozzeria (ZX12) wheels from the group buy of years ago and are due for a tire change,
I will pay you $25 and one reacharound to take the time to accurately measure ( plus or minus .001 ) the (2) front and (2) rear spacers.
ID, OD and length.
edit-- What I think - ID is easy,  copy the stockers. OD kinda easy -- seal ID plus a thou or two. Length - Critical !
Length is what I really need.
I have been told the 99 and up front spacers are differant from 98 ?
Please write yourself a note to measure during your next tire swap.
Edited by CALCXX
Share this post
Link to post
ID, OD and length.
If you ever choose to sell them some day, put me in line.  I don't know what they go for but one can dream.
Share this post
Link to post
Not ready yet. You have first dibs.
Share this post
Link to post
Cal, if I recall correctly the spacers are different size on the FI birds.  Put me second in line for those wheels. I tried to get Sean to sell me his, but it never happened.
Share this post
Link to post
I think this is only true of the front wheel? Someone, please correct me if wrong? Tim #2 dibs. Ever hear from Sean these days?
I followed Hanks link to the .com site and he mentioned Matt in Texas now has his Turbo XX. Anyone know Matt in Texas? He could be here but I don't know his screen name?
Would really like to talk to him.
Edited by CALCXX
Share this post
Link to post
Cal, Matt is in the armed forces serving overseas.
I haven't heard from him in a year.
Joe has all the stock spacers from my Carra's..
I gave him all my BB parts a couple years ago.
IIRC, they were stock dimensions but I built the turbo around 06-07
Share this post
Link to post
Thanks for the info. Hope Matt is well and no one is shooting at him.
I will check with Joe to see if he has the Carrozzeria spacers.
Thanks again.
Share this post
Link to post
Tell Joe to look for a baggie with wheel bearings and a red anodized spacer among other spacers.
I replaced the Carra spacers with custom SS stuff, made to proper dimensions so the bearing stack actually worked...lol
Share this post
Link to post
Measuring/copying just ain't gonna work.  Send me the wheels and I'll engineer some proper spacers.  When I get done enjoying the wheels I'll send them back to you with the spacers.
  • Like 1
Share this post
Link to post
Hank, that is why I want to talk to Matt. Copy yours. Bearing stack is questionable with the Carro wheels. Correct me if I am wrong but the original Carro spacers are not entirely correct and made out of aluminum. I know you had it figured out to the .001. It really is important I have the correct length to get the bearing stack right. I get it.  Carrozzeria did not get it right. that is why they only spec'd axle tourque to 34lbs.
Aluminum will not survive.. Agree? I know you figured this out. If I had the spec lenghts, I can also.
I plan to do SS also.I even have a piece for a lathe.
Edited by CALCXX
Share this post
Link to post
I keep up with him and his lovely family on FB.
Share this post
Link to post
Carra spec'd half the torque value on the rear axle due to possibly crushing the Carra POS 6061 alum wheel and bearing  spacers.
In addition, the shoulder that went through the bearing was to long, not capturing the inner race.
I just didn't think cutting rear axle torque in half was a good idea with 255HP and 155 lbs TQ was safe, so I redid all spacers.
Never had a drawing, just worked off the old spacers and new wheel.
As far as the wheels go, there were 2 rear designs.
The first one had a sprocket carrier which bolted to the wheel. This was prone to failure.
The second was a one piece design and worked well.
Share this post
Link to post
Good news. Mine does not have a carrier.
Share this post
Link to post
Today is the third day that I have been through that stack of boxes, and have found nothing resembling what we're searching for.
I will pull them out of the shed again tomorrow in daylight for yet another pick through.
Share this post
Link to post
Joe, I'll look thru my bike stuff but I'm sure I gave you every BB part I had except a very low mileage 03 swing arm and a complete cherry 97-98 cylinder head, cams and valve cover.. Let u know in a day or 2.
Share this post
Link to post
Joe found them. !!!!   He sent me a photo but I can;t seem to copy it from my phone.
You guys are my heros. When I grow up I wanna be just like you.
THANKS !!!!!!
Share this post
Link to post
Did this work? Hank, does this look familiar ?
Edited by CALCXX
Share this post
Link to post
I already sent that to Hank, who agreed.  But I've been too lazy to pull my Carro's and compare the bushings. Shouldn't there be 4, or does the spacer act as one?
Share this post
Link to post
I'm not sure but I think one of the OEM Honda spacers is used?
Hank, is that correct?
Share this post
Link to post
Cal, get Joe to send those spacers to you.
The red anodized one was supplied by Carra and installs on the brake side.
You will be able to see how they assemble once they are in front of you.
I can then explain the dimensions I changed.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
