NapoliBlackbird Posted October 30, 2017 Share Posted October 30, 2017 Looking for a good cell phone mount/case for an iphone 5s. Most of the cases on Amazon are for standard motorcycle/bicycle handlebars that won't mount on a Blackbird. Anybody got a recommendation? Quote Link to comment Share on other sites More sharing options...
DBLXX Posted October 30, 2017 Share Posted October 30, 2017 RAM 1 Quote Link to comment Share on other sites More sharing options...
NapoliBlackbird Posted October 30, 2017 Author Share Posted October 30, 2017 Thanks. That's what I was leaning towards based upon what I've read, using their fork stem base mount. Quote Link to comment Share on other sites More sharing options...
DBLXX Posted October 30, 2017 Share Posted October 30, 2017 For stem, clutch bolts, wide U-bolt....they all work. I always used the clutch bolts. Just nice and clean. I probably have a million dollars in RAM pieces in my tool boxes just rotting away. Quote Link to comment Share on other sites More sharing options...
JoWhee Posted October 31, 2017 Share Posted October 31, 2017 The ram mount on a 12 or 13 mm Allen key. Drop.the long end into.your yolk, the only way it's.coming out is if you flip the bike. Here's an old picture when I had the long clamp on it. It never came off, even when I took it off the bike and shook it vigorously. Quote Link to comment Share on other sites More sharing options...
NapoliBlackbird Posted October 31, 2017 Author Share Posted October 31, 2017 Thanks, that's what I decided to go with - ordered it already. Quote Link to comment Share on other sites More sharing options...
TuffguyF4i Posted December 22, 2017 Share Posted December 22, 2017 On 10/31/2017 at 5:15 AM, JoWhee said: The ram mount on a 12 or 13 mm Allen key. Drop.the long end into.your yolk, the only way it's.coming out is if you flip the bike. Here's an old picture when I had the long clamp on it. It never came off, even when I took it off the bike and shook it vigorously. How does that stop it from rotating? Quote Link to comment Share on other sites More sharing options...
JoWhee Posted December 22, 2017 Share Posted December 22, 2017 The Allen key won't rotate in the steering hub nut. One end of the ram bracket is clamped into the short end of the Allen key tightly and doesn't move. The other end is into the x-grip ball and it doesn't move either. The ram mount itself will rotate about 20 degrees, it's the nature of the mount, but it tends to want to stay vertical. TL;DR Friction Quote Link to comment Share on other sites More sharing options...
