TPXX Posted July 5, 2017 Share Posted July 5, 2017 Yeah, I know it's a Blackbird forum. The ABS pump module is clogged. The motor appears to work and the front brakes work, but the rear brake pedal is locked up.Brake line can be bled up to the unit, but on the other side it can't be bled. A new unit is almost $1300. Has anyone had any experience cleaning/fixing one of these things on another bike? Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted July 5, 2017 Share Posted July 5, 2017 Not much help, but if you're going to disassemble the system on that end, could you soak the module in a solvent (B-12 Chemtool) and see if it "degunks" the works? Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted July 5, 2017 Share Posted July 5, 2017 Any solvent put into a brake system is likely to ruin all rubber seals. There are some recalls on the rear brake system for sticking pedal and dragging brake, have they been done? Quote Link to comment Share on other sites More sharing options...
XXBirdSlapper Posted July 6, 2017 Share Posted July 6, 2017 Convert to standard brakes. Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted July 6, 2017 Share Posted July 6, 2017 Not under warranty anymore? I still have just shy of three years left my my second extended warranty. Quote Link to comment Share on other sites More sharing options...
TPXX Posted July 6, 2017 Author Share Posted July 6, 2017 2 hours ago, superhawk996 said: Any solvent put into a brake system is likely to ruin all rubber seals. There are some recalls on the rear brake system for sticking pedal and dragging brake, have they been done? Recall for sticking pedal due to road debris was done. They added a deflector or some such. Now the pedal is hydraulically locked 1 hour ago, XXBirdSlapper said: Convert to standard brakes. That is an option, just hook the rear master cylinder directly to the rear caliper and bypass the abs. 1 hour ago, OrganDonor said: Not under warranty anymore? I still have just shy of three years left my my second extended warranty. No more warranty, I should have gotten the extended but did not. Mine is a 2007/2008 model. Quote Link to comment Share on other sites More sharing options...
XXBirdSlapper Posted July 6, 2017 Share Posted July 6, 2017 1300? Unless I could find a good used unit cheap I would consider converting. That could be a big liability when it comes time to sell though. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted July 6, 2017 Share Posted July 6, 2017 17 hours ago, TPXX said: The ABS pump module is clogged What would it be clogged with? Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted July 6, 2017 Share Posted July 6, 2017 Talk to a dealer. I've read of a few of these units having that issue and there may be a free repair, kinda like a recall but without notifications sent out, I think it's called a repair campaign. If not, maybe a call to corporate would work. I also read of one guy that whacked the pedal with his heel a few times when it would stick and it would then work for a while. If it'll free up, then bleed it out maybe it'll fix it. Maybe smack the ABS unit with a small hammer if the pedal won't free it up. If it'll free up I'd go out and do some intentional hard braking to activate the ABS and get shit moving in there, then bleed it to flush out any corrosion debris. It's unlikely clogged in the typical sense of stuff getting into it, I'm guessing moisture and lack of activation lead to a stuck valve. If it works I'd add doing a 'lock up' to my regular riding routine to keep it from sticking again, it's also good practice to know what it feels like. Tho deleting it may hurt resale value, it probably won't drop it by $1,300 and some people might even find it a bonus since it appears to be a troublesome unit. Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted July 6, 2017 Share Posted July 6, 2017 Have read of people cleaning the motor and system out on cars and bikes. Worth a shot to do some research and attempt to fix it. Not like it works now... Also might gain some knowledge in the process for later use. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted July 6, 2017 Share Posted July 6, 2017 Or you could sell it and buy a XX. 2 Quote Link to comment Share on other sites More sharing options...
TPXX Posted July 11, 2017 Author Share Posted July 11, 2017 Dealer was not helpful at all. They said it was way to long out of warranty to cover. I showed them some forum links where Kawasaki had replaced the abs units out of warranty and this appeared to be a bit of an issue with the bike. They called Kawasaki and they said no as well. So I did a bunch of research and found that the ZZR 1400 abs unit has been used as a replacement for the concours, and I was able to get a used one for about $300 vs $1300 for a new one. It is on the way. In the meantime I played with my abs and think the solenoid to the rear wheel is sticking. I wacked it a couple of times with a dead blow hammer and it worked for a few miles, then locked the brake pedal again. So the rear wheel abs is bypassed right now awaiting the new unit to come in. May be time to sell it and get a ktm adventure Quote Link to comment Share on other sites More sharing options...
