Stator plug
The Krypt Keeper
Usually check this plug once every couple years. I just checked it while the tail section was off and the plug shows the signs of failure in the making.
My volt meter on the bike never showed any sign of fluctuations on my last ride so that is a good sign. Did a quick check of stator and R/R and both check out as well.
Will need a new plug and pin connectors to install. Doubt honda sells these, anyone got a source to buy the 3 connector?
Thanks
Got a couple pics of what I found.. last time I checked the plug it looked brand new.
Will end up removing about 2" or so of wire on the r/r side.
All good, will have it fixed soon enough.
Thanks for the link John, had been looking at some weatherproof ones from msd but cant find wire gauge size listed on amazon.
I recently changed stator and still have old one including wires and terminal. I can cut wires off stator and mail them to you. wires and block in good shape
I have a dead stator on the shelf back at the house too.
... Don't recall the condition of the connectors though.
10 hours ago, John01XX said:
John,
have you used this yet?
does it allow you to keep your OEM stator connector?
I have had a mosfet R/r sitting on the shelf for over a year, looking for connectors that would let me keep the stator plug OEM for a " just in case" field swap if I had a failure.
Going to order one today anyway.  But I had to ask.
Thanks for the link.
6 hours ago, redxxrdr said:
John,
Good thought.
