wire color codes for the headlights ?
John01XX
John, if you've got a volt meter, it's very easy to figure out. Put the meter on DC Volts and touch one lead to the frame (ground), with the headlight on and the dimmer switch set to low beam, one of the wires will have voltage and the other one no voltage. Check both wires to make sure of that. Then, keeping one of the meter leads on the ground, touch the other meter lead to the second wire and turn on the high beam switch.......should be voltage at the one that didn't have voltage on the first test. Turn it off and on a couple of times to make sure that everything is functioning as it should.
