Chewtoy Posted September 11, 2013 Share Posted September 11, 2013 After 28k miles, the DID standard O-Ring chain has stretched. What's the current best value chain and vendor to order from? Guess I need to get a rivet tool as well. Thanks Quote Link to comment Share on other sites More sharing options...
cecome Posted September 11, 2013 Share Posted September 11, 2013 Hobi set me up, check with him!! Quote Link to comment Share on other sites More sharing options...
Chewtoy Posted September 22, 2013 Author Share Posted September 22, 2013 Got a DID Quadra and a Motion Pro chain breaker. Install went slick. Nice and quiet chain now. Ready for another 28+k miles! Quote Link to comment Share on other sites More sharing options...
EVLXX Posted September 24, 2013 Share Posted September 24, 2013 How do you KNOW it's chain time ? That's an open question to all members. I'm curious if there is any difference in the testing and decision making processes.... here. I've always followed the stretch limit practice, myself. Quote Link to comment Share on other sites More sharing options...
Chewtoy Posted September 24, 2013 Author Share Posted September 24, 2013 Uneven stretch, caused variation in noise when underway. Quote Link to comment Share on other sites More sharing options...
EVLXX Posted September 24, 2013 Share Posted September 24, 2013 Hence why you should check your chain tension in various parts of the chain, by rolling your bike forwards or backwards. I wonder though... would that eventually just even out? I don't know... to be honest I never really put this much thought into Chain Wear. Chain Lube, Yes, Chain Wear... as for how to TEST for usable service life limits No. Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted September 24, 2013 Share Posted September 24, 2013 I had a section on my original chain start to bind. I am pretty good and cleaning and lubing also. It was well within the stretch limits and still in the green Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted September 24, 2013 Share Posted September 24, 2013 I had a section on my original chain start to bind. I am pretty good and cleaning and lubing also. It was well within the stretch limits and still in the green If you change your sprocket size, you can't use the green for a gauge anymore. Quote Link to comment Share on other sites More sharing options...
EVLXX Posted September 27, 2013 Share Posted September 27, 2013 Wear limit.... 1% > pitch .... really? But, I found another article that said for chains with sprocket sizes smaller than 67 teeth... that 3% was an allowable maximum. Quote Link to comment Share on other sites More sharing options...
RTGwalt Posted October 2, 2013 Share Posted October 2, 2013 I replace the chains when they get noisy. I've found that to be roughly 20k miles - whether I maintain them well or not. Quote Link to comment Share on other sites More sharing options...
runner Posted October 25, 2013 Share Posted October 25, 2013 Kinks in the chain indicate the wear for me...kinda strange since the bird is the only MC (that I remember) that's had the kinks appear. (I have ridden MC's since 1970...). I am looking at the DID as mentioned above. Quote Link to comment Share on other sites More sharing options...
EVLXX Posted October 26, 2013 Share Posted October 26, 2013 Kinks in the chain indicate the wear for me...kinda strange since the bird is the only MC (that I remember) that's had the kinks appear. (I have ridden MC's since 1970...). I am looking at the DID as mentioned above. How do Kinks indicate wear ? To me, a Kink in the chain, where the chain wants to stay bent after going around the small front sprocket, means a Dirty chain, a Master Link that was tightened too much, or the use of a bad chain lubricant (causing the o-rings to swell too much). But NOT wear.... wear is Loose... wear is Stretched... wear is rust coming from inside the link. Personally... I lost track of when I took off my stock chain, but I'm thinking it was around 20K miles. At which point I changed it with the toughest chain I could find... an EK ZZZ chain. Which is still on there at 39K, and measures out to be only HALF worn.... So... yess the EK ZZZ cost a bit more, but it looks like it's going to last twice as long. PS. my suggestion is... 75-90W Gear Lube only. Quote Link to comment Share on other sites More sharing options...
Banshee Posted October 30, 2013 Share Posted October 30, 2013 I'm pretty sure I hit the stretch limit on the original OEM & replaced with a DID 530ZVM at 108,000km. I replaced the original OEM sprockets as well at that time. Quote Link to comment Share on other sites More sharing options...
Nova Scotia Mike Posted November 11, 2013 Share Posted November 11, 2013 110k on an oem chain?! What's your maintenance drill? Quote Link to comment Share on other sites More sharing options...
