silverbird1100 Posted August 25, 2008 Share Posted August 25, 2008 I thinking it would be nice to see when your charging system is going out or just for piece of mind at the least. I was thinking of rigging a small volt meter but you'd have to turn it on to check it. Anyone seen one that displayes it all the time? Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted August 25, 2008 Share Posted August 25, 2008 Its just how you wire it. Most folks don't want the constant current draw. Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted August 25, 2008 Share Posted August 25, 2008 You can ride with Pete (PlasticXXhead.) He can HEAR the battery dying... at least on Joe's bike at PRIXXT! Or, you can wire in a datel meter and stick it onto your triple clamp. There are a lot of folks who have them. If you're going to leave it on the bike, make sure you get a waterproof one. The data strip one they sell at Aerostitch isn't waterproof, but works out fine for some folks. Quote Link to comment Share on other sites More sharing options...
silverbird1100 Posted August 25, 2008 Author Share Posted August 25, 2008 That Datel meter is perfect. Can you get one in town or internet only? Quote Link to comment Share on other sites More sharing options...
BigMig Posted August 25, 2008 Share Posted August 25, 2008 I crudely connected a DATEL to the battery directly - and I turn it on only when riding. Nice info to have at all times. Anyone have a better way to see the output than "stuck to the triple clamp"? I was thinking of cutting a hole in the plastic, but haven't found a great-visibility location. Suggestions? Mike Quote Link to comment Share on other sites More sharing options...
Justin Posted August 25, 2008 Share Posted August 25, 2008 I have mine in the map pocket of my tank bag, next to the radar detector. Everything is wired inside the bag, so I just plug in the bag when I get on the bike. Quote Link to comment Share on other sites More sharing options...
wrgoudy Posted August 25, 2008 Share Posted August 25, 2008 I put a simple analog Borg Warner Voltmeter in the fairing panel on the right side, and wired it thru a $10.00 relay from Radio Shack that picks up only when running. Not waterproof, but haven't had any problems to date even when it gets full of water occasionally. Bill Quote Link to comment Share on other sites More sharing options...
Hobicus Posted August 26, 2008 Share Posted August 26, 2008 I just set my radar detector (Escort 8500) to show volts. Quote Link to comment Share on other sites More sharing options...
haWHYnXX Posted August 26, 2008 Share Posted August 26, 2008 +1 on the Datel. Mounted mine on top of the instrument cluster next to the radar detector: Quote Link to comment Share on other sites More sharing options...
RC Randy Posted August 26, 2008 Share Posted August 26, 2008 I just set my radar detector (Escort 8500) to show volts. I do the same with my Bel Quote Link to comment Share on other sites More sharing options...
silverbird1100 Posted August 26, 2008 Author Share Posted August 26, 2008 I just set my radar detector (Escort 8500) to show volts. I do the same with my Bel Come again? I have one sitting on my tankbag (8500) how the hell does it read volts? Nevermind, mine's the solo s2 Quote Link to comment Share on other sites More sharing options...
redwingedblackbird Posted August 28, 2008 Share Posted August 28, 2008 +1 on the Datel. Mounted mine on top of the instrument cluster next to the radar detector: So where did you mount the coffee maker? Quote Link to comment Share on other sites More sharing options...
Redbird Posted August 28, 2008 Share Posted August 28, 2008 +1 on the Datel. Mounted mine on top of the instrument cluster next to the radar detector: You do realize that you can use that detector as a voltmeter? Quote Link to comment Share on other sites More sharing options...
haWHYnXX Posted August 28, 2008 Share Posted August 28, 2008 +1 on the Datel. Mounted mine on top of the instrument cluster next to the radar detector: You do realize that you can use that detector as a voltmeter? Had the Datel first - but also like the bigger readout. +1 on the Datel. Mounted mine on top of the instrument cluster next to the radar detector: So where did you mount the coffee maker? Quote Link to comment Share on other sites More sharing options...
02XXCA Posted August 29, 2008 Share Posted August 29, 2008 +1 on the Datel. Mounted mine on top of the instrument cluster next to the radar detector: You do realize that you can use that detector as a voltmeter? Had the Datel first - but also like the bigger readout. +1 on the Datel. Mounted mine on top of the instrument cluster next to the radar detector: So where did you mount the coffee maker? Dammit, he never even offered me a cup! Quote Link to comment Share on other sites More sharing options...
Wockman Posted August 29, 2008 Share Posted August 29, 2008 I have one of these. Its just a LED that changes color to show voltage. Its small enough to mount anywhere. http://www.customdynamics.com/LED_battery_...Panel_Mount_LED Quote Link to comment Share on other sites More sharing options...
jjmcjames Posted September 4, 2008 Share Posted September 4, 2008 check this out... http://www.sportbikes.net/forums/fz6-mods/...stallation.html Quote Link to comment Share on other sites More sharing options...
Jetfixxr Posted September 4, 2008 Share Posted September 4, 2008 check this out... http://www.sportbikes.net/forums/fz6-mods/...stallation.html That's great but i am sure there is a smaller led to display voltage, i am working on finding a low voltage sensor that has a light, that's enough for me. Just something to alert me that i am not charging. Jet Quote Link to comment Share on other sites More sharing options...
Jetfixxr Posted September 6, 2008 Share Posted September 6, 2008 I have one of these. Its just a LED that changes color to show voltage. Its small enough to mount anywhere. http://www.customdynamics.com/LED_battery_...Panel_Mount_LED Now this is cool, and not a wallet raper. Jet Quote Link to comment Share on other sites More sharing options...
tripledigits Posted September 6, 2008 Share Posted September 6, 2008 I use an i4c gauge that draws hardly any current. I've had no problem in 2 years with it. It's not lit, but I can still read it at night with low light conditions. I velcroed it below the instrument panel as you can see. It's waterproof. I actually have a new spare one that's just been sitting around, if you want it. $48 shipped. I bought an extra one for a future bike that hasn't been bought. Quote Link to comment Share on other sites More sharing options...
