Hobicus Posted May 2, 2008 Share Posted May 2, 2008 Ever since I saw DeaconXX's under seat modification, I knew I wanted to do something similar. I just modified the tail section to add an additional 2.5 quarts of storage, by cutting the plastic and adding a piece of tupperware. Note that I used a GOOD, thick piece, not some cheap thin stuff. Here's what it looks like to start. Note that I've already removed the tail cowl and the two bolts that hold the rear fender. That causes it to drop down a bit. I've also pulled everything out of the way. Yes, you can still see the ScotOiler stuff, too. So here's what it looks like with the hole cut for the tupperware. This took quite a bit of time. I used a dremmel for most of the work, and doubled up the cutting disks for the main trimming, then went with a nice stone wheel to fine tune the hole. You will probably want to remove the tool section first, as it's huge and gets in the way. Here's a couple test fit shots without Epoxy: Here's how it looks after I glued it in with Epoxy. I used the Plasticweld stuff, which smells like acrylic when it's all done. Very hard stuff, you only have about 4 to 5 minutes to work before it's starts setting up. I did this in a 2 step process. First I mixed up a batch of epoxy, put it around the edges, and pressed the container through the opening. This forced some epoxy through, and you can see that on the underside of the container. I then added what was left of the epoxy to the edges of the container and waited for it to set up. Then I mixed up a 2nd batch and went back and filled any gaps with it, kind of like you would with spackle. Note that you can see that the Epoxy isn't perfect, smooth, or great looking, and you can see where it got UNDER the tail as well. I figure this is going to get covered in dirt pretty quick, and you won't be able to see through the container for long anyways. I tried to clean it up as best as I could, but making it look pretty was less important than making sure it didn't move. : After that, it was time to reassemble the rear fender bolts and reattach the tail cowl. Here's an idea of how much storage you get with this mod: Here's my tool kit, plug kit, cable lock for my Stich, and sunblock all fitting inside the container This took me about 2 hours, from start to finish. Total cost, about $10. Quote Link to comment Share on other sites More sharing options...
Jaygermeister Posted May 2, 2008 Share Posted May 2, 2008 Nice. Could you take some pics from the other side? Can you see it from behind the bike if the fender is trimmed off? Quote Link to comment Share on other sites More sharing options...
Keith Posted May 2, 2008 Share Posted May 2, 2008 Any possibility of interference with the tire on a hard bump? It sure adds a lot of storage area, especially with your Smuggler. Thanks for the tip! :icon_clap: Quote Link to comment Share on other sites More sharing options...
DaveK Posted May 2, 2008 Share Posted May 2, 2008 Hobi....sorry....Master Fabricator Hobi.... That fucking rocks man. Nice work !!! Quote Link to comment Share on other sites More sharing options...
Hobicus Posted May 2, 2008 Author Share Posted May 2, 2008 Nice. Could you take some pics from the other side? Can you see it from behind the bike if the fender is trimmed off? I don't think you can, there's enough room for me to put a Mototeck undertail in and still have this container there. Or at least, there is, from what I remember when we put Redd's Mototeck in. By other side, I'm assuming you mean from underneath, so you can see how much space is there: Here's how much space is underneath it, on the side stand. I sat on it and bounced, and had my wife check, and there seems to be plenty of room. I'll monitor it over the next few weeks (I have some great roads for testing purposes ) and make sure it doesn't hit. It only drops about 1.5- 2 inches below the fender. Quote Link to comment Share on other sites More sharing options...
Jaygermeister Posted May 2, 2008 Share Posted May 2, 2008 Great mod. Thanks for the pics. Quote Link to comment Share on other sites More sharing options...
Hooplehead Posted May 2, 2008 Share Posted May 2, 2008 Hope you used good tupperware! :icon_nana: I imagine cheap crap gets brittle in the winter. I hear that running over padlocks will cupp tires? Don't hide your weed in the bottom if you're going to use clear, that's all I'm saying! Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted May 2, 2008 Share Posted May 2, 2008 Great idea... I have to do something like that but the space will be taken by electronics.. I realize it's in a hard place to see but I'd still put something in it, or paint it so you can't see inside it from under the bike. Edit... what power blocks do you have in there? Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted May 2, 2008 Share Posted May 2, 2008 Well, that is cool, fo sure! I really missed the space the quad has from the mod like that I did, and didn't think it could be done on the bike, but looks like it can. New project!!! Quote Link to comment Share on other sites More sharing options...
PlasticxxHead Posted May 2, 2008 Share Posted May 2, 2008 Rich, I hate you.. I had this idea about a month ago, and was all amped up to try it out... I got the idea from Mac KiwiXX. he bent up some aluminum and made a little coffin. Any reason you didn't spray paint the tupperware first, or rhino line it... or kept the top able to fit...? Then you could store your lunch and a snack pack under the seat on your long trips... Well you know with your hand there it doesn't tell us how much space you have .. Small hands next to big bikes makes it hard to judge real scale.. missing you guys more every day.. Buying a new bird July 10th... find me one... See you soon... ps . I like your astroglide tube in there.. very inviting Quote Link to comment Share on other sites More sharing options...
TFT Posted May 3, 2008 Share Posted May 3, 2008 Nice work Rich!! I have wondering how I could increase storage space under there too. I know I realy appreciate when you do these projects and present the info here on the forum. I'm sure many others do too. Thanks. That is a lot of clearance!!! A cetain woman I know says that according to the way I measure that must be at least 8 inches. Quote Link to comment Share on other sites More sharing options...
Involute Posted May 3, 2008 Share Posted May 3, 2008 Leave it to Rich to come up with ways to pack more stuff in an ass. Quote Link to comment Share on other sites More sharing options...
Hobicus Posted May 4, 2008 Author Share Posted May 4, 2008 Leave it to Rich to come up with ways to pack more stuff in an ass. :icon_iloveyou: Quote Link to comment Share on other sites More sharing options...
BackStreet Posted May 4, 2008 Share Posted May 4, 2008 Really? Only $10 and it looks like......well......$10! :icon_shifty: Quote Link to comment Share on other sites More sharing options...
Mekanix Posted May 4, 2008 Share Posted May 4, 2008 :icon_clap: :icon_clap: Dude, that's sooo cool! I like that almost as good as your jiggling sig file. Nice job! Quote Link to comment Share on other sites More sharing options...
CxBXR Posted May 4, 2008 Share Posted May 4, 2008 Could use a silver aluminum deep dish cooking tray in its place for a "billet" look. OR OR go Stainless Quote Link to comment Share on other sites More sharing options...
cabinfever Posted May 5, 2008 Share Posted May 5, 2008 Cool mod... I wonder if something like that would work on the viffer. When I had my ZRX, you could mod the underseat big enough to hold a gallon of milk if you had pod air filters on the carbs. Quote Link to comment Share on other sites More sharing options...
lexxus Posted May 12, 2008 Share Posted May 12, 2008 Great Mod Rich,. I've looked in honda's tupperware section on there site, but did'nt find the part number for the 2.5 quart. Could you,would you,Post the number. My m&m's are calling. Quote Link to comment Share on other sites More sharing options...
RichardCranium Posted May 12, 2008 Share Posted May 12, 2008 Great Mod Rich,. I've looked in honda's tupperware section on there site, but did'nt find the part number for the 2.5 quart. Could you,would you,Post the number. My m&m's are calling. From Honda that same tupperware would cost around $149.99 Quote Link to comment Share on other sites More sharing options...
lexxus Posted February 11, 2012 Share Posted February 11, 2012 How is that mod holding up? Quote Link to comment Share on other sites More sharing options...
rcskisfast Posted February 11, 2012 Share Posted February 11, 2012 Hobi my bike has had that mod for about 4 yrs. Got the idea from Vern's wife when we were at West Coast Bash in Montrose. Quote Link to comment Share on other sites More sharing options...
slowrideCX Posted February 12, 2012 Share Posted February 12, 2012 How is that mod holding up? It fell out last year at PRIXXT 11 and we had to make a new pan out of aluminum. I helped him fill the gaping hole in his rear!!!! Quote Link to comment Share on other sites More sharing options...
lexxus Posted February 12, 2012 Share Posted February 12, 2012 LMAO.. Quote Link to comment Share on other sites More sharing options...
Tom Posted November 5, 2021 Share Posted November 5, 2021 Disgusting thread ressurection. I've been thinking about this, I need somewhat bigger space under the seat. What are my options (aside from the elegant Tupperware solution ) - can the undertray plastic be welded? ABS I supposed, can I make into a specific shape, or am I destined for flat pieces and welding. Also, whats some minimal clearance from tyre to the undertray, wouldn't want to have those two touch Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted November 5, 2021 Share Posted November 5, 2021 2 hours ago, FTM said: Also, whats some minimal clearance from tyre to the undertray, wouldn't want to have those two touch Maybe get the fattest guy you can find, have him sit on it and do some measuring? Quote Link to comment Share on other sites More sharing options...
