scott s. Posted February 22, 2006 Share Posted February 22, 2006 getting ready to put the bird back together and i noticed that upper mount for the upper fering stay is cracked on both verticle sides. having a hard time finding someone that can weld aluminum. is this something i should be real concerened about? any input would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Byrdman Posted February 22, 2006 Share Posted February 22, 2006 getting ready to put the bird back together and i noticed that upper mount for the upper fering stay is cracked on both verticle sides. having a hard time finding someone that can weld aluminum. is this something i should be real concerened about? any input would be greatly appreciated. These are the two mounts that are on the steering neck correct? I would be very careful, an inexperienced welder and a bad weld job could weaken the neck. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted February 25, 2006 Share Posted February 25, 2006 Or are you talking about the small bolt on subframe for the upper? If you are buy a new one. Mine is steel. :icon_think: Need pics. Quote Link to comment Share on other sites More sharing options...
CatBird Posted February 25, 2006 Share Posted February 25, 2006 getting ready to put the bird back together and i noticed that upper mount for the upper fering stay is cracked on both verticle sides. having a hard time finding someone that can weld aluminum. is this something i should be real concerened about? any input would be greatly appreciated. Found the exact thing in my '02 when I stripped it down after the accident last summer. The crack wasn't deep but when I had a friend weld it he found oxidation which he said meant the crack had happened some time before. I'm wondering how many others have had this happen. Hmmmm. Quote Link to comment Share on other sites More sharing options...
