ElChingonCabron Posted July 27, 2003 Share Posted July 27, 2003 Anyone know what year models of the 900RR will work for the shock swap? TIA- Sanch Quote Link to comment Share on other sites More sharing options...
Flying Scott Posted July 27, 2003 Share Posted July 27, 2003 Its all here folks...... CBR 900 93-95 http://www.cbr1100xx.org/newhome.html?mods...on/index.html&2 Quote Link to comment Share on other sites More sharing options...
ElChingonCabron Posted July 27, 2003 Share Posted July 27, 2003 Sweet, thanks..... You will need a shock from a '93-'95 model; the later years won't fit. This will carry one of the following part numbers: MWO-003 MWO-0132A MWO-0132B MAE-0032B I found a MWO-003 on a '98 model...should fit though right? The doode says it is 12 3/4 in long from center to center on the bolt holes...anyone care to measure theirs? :cool: Quote Link to comment Share on other sites More sharing options...
RodeRash Posted July 28, 2003 Share Posted July 28, 2003 I found a MWO-003 on a '98 model...should fit though right? The doode says it is 12 3/4 in long from center to center on the bolt holes...anyone care to measure theirs? That's the one. Quote Link to comment Share on other sites More sharing options...
Northman Posted July 29, 2003 Share Posted July 29, 2003 The MWO-003 is the same shock I have. 12.5 inches center to center, and it's stock from a '93 model. Quote Link to comment Share on other sites More sharing options...
Hokie Posted August 4, 2003 Share Posted August 4, 2003 I'll take a spring. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted August 4, 2003 Author Share Posted August 4, 2003 Ok, looks like enough people to make it cost-effective. Now the question...do we go for Racetech's recommendation of 16.5kg, the stock 16.8, or something else? Quote Link to comment Share on other sites More sharing options...
Hokie Posted August 4, 2003 Share Posted August 4, 2003 Well I am in the 210lb class so 16.5 I guess. How big is Swampnut since he is bottoming out the 16.0? Quote Link to comment Share on other sites More sharing options...
Northman Posted August 4, 2003 Share Posted August 4, 2003 I've only bottomed out the 16.0 a few times, and each time was 2-up, and loaded with luggage. I say the 16.5 is the way to go. Stronger for the loaded times, but optimal for solo canyon carving. :twisted: Quote Link to comment Share on other sites More sharing options...
JasonW Posted August 5, 2003 Share Posted August 5, 2003 Count me in also........maybe. Apparently I'm on the lighter side here. I weigh around 170, depending...... and rarely ride two up. Would I be better off buying one of your guy's spring once you upgrade? Any suggestions? I find the stock spring to be a little much, but then again, I don't want to bottom out during those few times that I do have a pillion. Either way, I'll need a spring. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted August 5, 2003 Author Share Posted August 5, 2003 How big is Swampnut since he is bottoming out the 16.0? 215#, plus the Beetle Bags. I'm not bottoming when I ride solo, but it's definitely too soft. With even a small passenger I can bottom it on hard turns. Jason, you should run your numbers through the calculator on the RaceTech site and see what it recommends. Quote Link to comment Share on other sites More sharing options...
RodeRash Posted August 5, 2003 Share Posted August 5, 2003 I ran my numbers through the racetech site. Per racetech, for my weight, the recomended spring is 16.5. Further down the list, I find that racetech considers the 16.8 spring ideal for a 170 lb. rider. When I started the calculations, I entered my weight as 180. Looks like there are some problems with their calculations. Has anyone called racetech and asked for recomendations? Quote Link to comment Share on other sites More sharing options...
Hokie Posted August 5, 2003 Share Posted August 5, 2003 How big is Swampnut since he is bottoming out the 16.0? 215#, plus the Beetle Bags. I'm not bottoming when I ride solo, but it's definitely too soft. With even a small passenger I can bottom it on hard turns. Jason, you should run your numbers through the calculator on the RaceTech site and see what it recommends. I am the same size plus GIVI setup. Quote Link to comment Share on other sites More sharing options...
MiDNiTXX Posted August 13, 2003 Share Posted August 13, 2003 Am I too late to get in on this? It still going down? Quote Link to comment Share on other sites More sharing options...
SwampNut Posted August 13, 2003 Author Share Posted August 13, 2003 No, and yes. I plan to get on it next week, don't have time this week. We'll have to figure up the final commitments, get the cash together, then do the order. Quote Link to comment Share on other sites More sharing options...
John01XX Posted August 19, 2003 Share Posted August 19, 2003 I have a stock 900RR shock that was given to me. It is Yellow tho so will have to paint it but free none the less. Where refering to the "stocker" does that mean the stock Bird spring or the stock RR spring ? I am a light weight at 150 lbs and rarely ever ride two up. Can I use either the stock Bird or stock RR spring for my set-up ? Quote Link to comment Share on other sites More sharing options...
aquokka Posted August 5, 2004 Share Posted August 5, 2004 if the order hasn't already been placed then count me also if the spring rate will work for a 180 lb solo. will they ship them out seperately to different addresses? cheers andrew Quote Link to comment Share on other sites More sharing options...
Sauron Posted August 5, 2004 Share Posted August 5, 2004 If you still havn't ordered these Carlos, I'm interested, although I'll have to find the shock too... Quote Link to comment Share on other sites More sharing options...
demon Posted August 5, 2004 Share Posted August 5, 2004 I was wondering if the stock bird spring would fit the RR shock. The stock bird spring is more than 16KG, right? Or is the spring a different dia? Anyone persued the 954/929 shock swap yet? probably need a new lower link for that swap though, the shock is a different length. Quote Link to comment Share on other sites More sharing options...
