TechnoGecko Posted November 20, 2004 Share Posted November 20, 2004 Alright. I give up. I've been trying to get the carbs off this bike for over two hours now. Ive loosened the clamps at the bottom and wiggled back and forth and pulled like all hell. Even got someone else to help pull. Used a 2x4 as a pivot point, you name it. They haven't even budged. I've sprayed the hoses with wd40 hoping to work them loose, not a chance. Got the jetkit, now I can't install it because I can't get the carbs off! ARGH! Any ideas? The shop manual says 'ease the carbs off, however they may be snug' Snug?!?! More like welded on. *sigh* Ideas? Quote Link to comment Share on other sites More sharing options...
K9XX Posted November 20, 2004 Share Posted November 20, 2004 :shock: :shock: WoW!! I've never heard of this trouble. Perhaps the last owner used thread lock to hold the carbs in the boots I remember mine coming out nice and easy, like too easy. Did you try putting a torch to the carb bowls yet Sorry bro, I would be the guy scratching his head while I watched you jerk on them if I was there. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted November 20, 2004 Share Posted November 20, 2004 I had a very hard time getting mine off. Just make sure the clamps are loose and wiggle a lot while pulling. There isn't anything else holding them on. Or-call Nik. :grin: Quote Link to comment Share on other sites More sharing options...
wrgoudy Posted November 20, 2004 Share Posted November 20, 2004 My XX is injected, but on my old XS11 you couldn't pull the carbs out of the boots as much as you had to "bend" them out by grabbing them at the back and pushing straight down and up to break them loose, for what it's worth. Hope this idea helps. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted November 20, 2004 Share Posted November 20, 2004 Rock them forward and back, then try to get one end out then the other and walk them out. for reinstallation wipe the inside of the boots with Armour All. Quote Link to comment Share on other sites More sharing options...
TechnoGecko Posted November 20, 2004 Author Share Posted November 20, 2004 I've just spent another 2 hours this morning rocking and pulling, these thing will not come out to save my soul. The only other idea I had was to use a heat gun to warm up the rubber and hopefully have it get soft enough to brake loose. But obviously gas + heatgun = diaster Sooooo.... I was able to install the needle and springs without removing the carbs, I just need to change the jet now which I can't get to unless I remove the carbs. The bird uses 142s right now, and this kit says to use 136s or 140s. Any chance if I just say screw it and see how it runs on the 142s that it'll preform decent? I've been yanking, pulling, wiggling, rocking, screaming, and crying over these carbs now for over 5 hours. I can't believe this is so diffucult. It took me a good hour on the Magna, but this is insane! Ideas? Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted November 20, 2004 Share Posted November 20, 2004 You've got to get them out. Dyno Jet jet #'s mean nothing compared to Honda #'s. You sure all 4 clamps are completely loose? I never had much problem getting mine out. That being said, stock or aftermarket exaust and air cleaner? Quote Link to comment Share on other sites More sharing options...
CBR-RR-XX-CESS Posted November 20, 2004 Share Posted November 20, 2004 Don't know if this would work just a thought,can you slide a feeler gauge in to break the seal and you might try a chemical hot pack if you don't like the idea of a heat gun. And in my past on other bikes I had to twist them to break the seal. Goodluck Quote Link to comment Share on other sites More sharing options...
TechnoGecko Posted November 22, 2004 Author Share Posted November 22, 2004 Yeeaaaa........ It is -not- possible to get the carbs off this bike. Don't get me wrong, I've removed carbs off other bikes ( both the Magna and Shadow ) and while its diffucult, at least you can see yourself making progress. Took me about 20-30 minutes on the Shadow and a good hour on the Magna. I tried for over 20 hours to remove those carbs. Its just not humanly possible. Heat gun, wedging a screwdriver between the seals, wd40, rubber lubricant - you name it. There was no way they were comming off. Now having spent $120 on this jet kit I was really pissed. But dammit, no bike was going to beat me! I removed the tops off the carbs and changed the needles and drilled the hole just fine, the diffucult part was in the jets. With some help and alot of patience I was able to remove the float bowls from the carbs ( took me two hours to remove all four ) and change the jets. Then I managed to get them all back on! It was so incredibly time intensive, but it worked. So in the end I got the bike jetted, and boy does it scream faster than it ever has before. The flat spot is totally gone, and the bike runs like a dream. Unforuntley I broke the choke cable *slaps forehead* so I've got one on order that'll be here Wednesday - but besides that its all done! I'll post some pictures of the bike when I get a chance, its going to be a chaotic beginning of the week here however. So in the end all I have to say is "fuck you" to the Honda service manual that says "Ease the carbs off". Ease my ass, I don't think Arnold could get those suckers off there. But in the end, its got the kit on - runs great. My knuckles are all bloody from working in the tiny area, but all in the name of a good running bike! Thanks for your help Success! Quote Link to comment Share on other sites More sharing options...
Involute Posted November 22, 2004 Share Posted November 22, 2004 Nice work! Do you want to Jet mine for me? Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted November 22, 2004 Share Posted November 22, 2004 You DID take the safety clips off, didn't you? :ducking: Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted November 23, 2004 Share Posted November 23, 2004 THAT must have been a PITA!! I remove my carb bank just to adjust the pilot screws. Can't imagine replaceing jets while installed. My choke cable has been broke for years, right at the end where it snaps into the bracket at the carbs. I just zip tie it into the bracket every time the carbs come out. How are you going to check your valves?.... carbs have to come out. :cry: Just thought of something. You do know that there is a clamp on either side of the rubber intakes??? If you can't break them loose at the carbs maybe you can at the head. Quote Link to comment Share on other sites More sharing options...
97bbxx Posted February 9, 2021 Share Posted February 9, 2021 I'm having the same exact problem as we speak. I had the carb of about 6 months ago and it came off easily. I had an aftermarket full exhaust that I installed at the same time I rebuilt and jetted the carbs. But now I can figure out what to do I have lossened the clamps on both sides but I am running out of ideas. If you figured it out please share cause I love my bird but right now I wana throw this bitch in to a lake and say fuck it. I've gone over my service manual 20 times to make sure I didn't over look anything or for something stupid. Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted February 9, 2021 Share Posted February 9, 2021 Cold in Pittsburgh, ain't it? They gotta be nice and warm to flex enough to come off. 1 Quote Link to comment Share on other sites More sharing options...
SwampNut Posted February 9, 2021 Share Posted February 9, 2021 Heat gun? Heat the whole garage? Wait until summer? Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted February 9, 2021 Share Posted February 9, 2021 29 minutes ago, rockmeupto125 said: Cold in Pittsburgh, ain't it? They gotta be nice and warm to flex enough to come off. Exactly what I was thinking. Also make sure you've loosened the clamps enough. Not just released tension, they need to be able to let the boots expand to get over the ridge they're sitting in. If the bike will still start you could run the engine for a while to get some heat in the boots. Quote Link to comment Share on other sites More sharing options...
NoOne65 Posted February 9, 2021 Share Posted February 9, 2021 2 hours ago, 97bbxx said: I'm having the same exact problem as we speak. I had the carb of about 6 months ago and it came off easily. I had an aftermarket full exhaust that I installed at the same time I rebuilt and jetted the carbs. But now I can figure out what to do I have lossened the clamps on both sides but I am running out of ideas. If you figured it out please share cause I love my bird but right now I wana throw this bitch in to a lake and say fuck it. I've gone over my service manual 20 times to make sure I didn't over look anything or for something stupid. Mine were hard as rock even in the height of summer...it was extremely hard to get them off...ultimately I bought some off of ebay that were not as hard and cut the old ones off Quote Link to comment Share on other sites More sharing options...
XXitanium Posted February 9, 2021 Share Posted February 9, 2021 "Oil of Wintergreen is methyl salicylate, an agent that keeps rubber pliable. The Xylene opens the pores of the rubber so the Oil gets in. Over time the Xylene evaporates." https://www.amazon.com/Methyl-Salicylate-1000ml-Purity-Wintergreen/product-reviews/B00MR72E3U?reviewerType=all_reviews DON'T DRINK IT. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted February 9, 2021 Share Posted February 9, 2021 WOW! Never would have guessed, that's an awesome tip. One of the reviewers says he uses alcohol, so assuming that's effective, you're far better off than trying to stay safe with Xylene. It is easily absorbed into tissue and shouldn't be used without a respirator. 1 Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted February 9, 2021 Share Posted February 9, 2021 I think Joe is right, carefully use a heat gun or hair dryer to warm the boots and rock the carbs in all directions while pulling. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted February 10, 2021 Share Posted February 10, 2021 ...it's not me in the post in the image.. https://cbrforum.com/forum/general-tech-9/best-way-swell-expand-restore-rubber-carbs-156202/ Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted February 10, 2021 Share Posted February 10, 2021 6 hours ago, XXitanium said: "Oil of Wintergreen is methyl salicylate, an agent that keeps rubber pliable. The Xylene opens the pores of the rubber so the Oil gets in. Over time the Xylene evaporates." https://www.amazon.com/Methyl-Salicylate-1000ml-Purity-Wintergreen/product-reviews/B00MR72E3U?reviewerType=all_reviews DON'T DRINK IT. Nice to know! The first two reviews are from people using it for motorcycle carb parts, then another a few down from that. Along with a warning to not let them soak too long as they'll swell up. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted February 10, 2021 Share Posted February 10, 2021 The one f'n guy was baking them in solution in the oven?! I would like to try it some time in open air. Quote Link to comment Share on other sites More sharing options...
97bbxx Posted February 10, 2021 Share Posted February 10, 2021 I don't know why I never thought of a hair dryer I heated and worked for an hour and got it off finally. I'm also ordering some of that oil for the future. But it's off new boots and carb kit are on my list for tommorrow Quote Link to comment Share on other sites More sharing options...
SwampNut Posted February 10, 2021 Share Posted February 10, 2021 Oil of wintergreen is surprisingly dangerous, and Xylene is plenty dangerous. Anyone trying this should research and not jump into it. 1 Quote Link to comment Share on other sites More sharing options...
