4U2NV Posted May 5, 2003 Share Posted May 5, 2003 The owners manual states that you are not suppose to wash the Bird with a high power sprayer as the water pressure will damage the chain and get into the air intakes :shock: What about water entering the air intakes when using garden hose pressures? I forgot to put socks/rags into the intakes and accidentally sprayed water down them… will the water cause problems or mess up the filter/air box? What about sucking water down the intakes at highway speeds during a rain storm? Just wondering :wink: Quote Link to comment Share on other sites More sharing options...
Andy1100 Posted May 5, 2003 Share Posted May 5, 2003 70-80 on the highway IN DAYTONA and yes TORRENTIAL RAIN, no problems. I'm not bitter. :sad: Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted May 5, 2003 Share Posted May 5, 2003 Joe, 110mph in the rain??? :loony: Quote Link to comment Share on other sites More sharing options...
CBRXX Posted May 5, 2003 Share Posted May 5, 2003 There are two small drain holes in the bottom of the airbox, under the filter where the ducts enter. They are off to the left side, in each of the wells, so the water drains easier while on the sidestand. They are only about 1/8' to 3/16" in diameter. I noticed one of mine was clogged with sand/dirt and I have under 4000 miles. You definitely want to check these any time you are servicing the filter, so that any water that does enter, has someplace to drain. Steve Quote Link to comment Share on other sites More sharing options...
4U2NV Posted May 9, 2003 Author Share Posted May 9, 2003 THANKS EVERYONE FOR THE INFO/INPUT :wink: Quote Link to comment Share on other sites More sharing options...
