rockmeupto125 Posted June 4, 2022 Share Posted June 4, 2022 So I got this new bike, and thought I'd do the right thing and take the warning sticker with all the writing on it off me deep metal flake tank. It was over 80 today and I figured out would be easy... And it was. Came off get nicely with my plastic razor blade. And now I've got this goo rectangle I can't get off what the hell? I've rubbed it with alcohol and window cleaner...a lot. What's the next step? Goo Gone? Vinegar? Tequila? Brake fluid? Quote Link to comment Share on other sites More sharing options...
RXX Posted June 4, 2022 Share Posted June 4, 2022 Acetone, duh. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted June 4, 2022 Share Posted June 4, 2022 17 minutes ago, RXX said: Acetone, duh. Duh. Amateur. I've had success with different stickers using high-proof isopropyl or goo-gone. Quote Link to comment Share on other sites More sharing options...
FiXXation Posted June 4, 2022 Share Posted June 4, 2022 3M Adhesive Remover Quote Link to comment Share on other sites More sharing options...
DBLXX Posted June 4, 2022 Share Posted June 4, 2022 When you dump it sliding down the pavement should work. Quote Link to comment Share on other sites More sharing options...
poida Posted June 4, 2022 Share Posted June 4, 2022 eucalyptus oil Quote Link to comment Share on other sites More sharing options...
XXitanium Posted June 4, 2022 Share Posted June 4, 2022 I missed the thread. Whadjaget? Pictures? Quote Link to comment Share on other sites More sharing options...
XXitanium Posted June 4, 2022 Share Posted June 4, 2022 Just now, XXitanium said: I missed the thread. Whadjaget? Pictures? ...the Yamaha,,,,? Quote Link to comment Share on other sites More sharing options...
tomek Posted June 4, 2022 Share Posted June 4, 2022 (edited) Many spray on plastic/paint cleaners/polishers will help removing whatever reside is left after sticker removal. Spray it on offending areas, wait couple minutes, etc. Now, acetone,,,, it is unsafe to use unless you are a professional like myself. And I doubt you are. Edited June 4, 2022 by tomek Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted June 4, 2022 Share Posted June 4, 2022 Angle grinder with a 3M Cubitron grinding wheel. Use medium pressure to start, ease up when you smell gas. When it catches fire you can go on to the next task while it does all the work for you. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted June 4, 2022 Share Posted June 4, 2022 With most stickers, if you peel them slowly, sometimes painfully slowly, the adhesive stays with the sticker. Scraping or rushing is almost always going to leave a mess. Heat helps. Heating the object is much more effective than heating just the sticker. Luckily this object comes with it's own heat source, you just need to switch it to heat mode, a match down the hole is all it takes. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted June 4, 2022 Share Posted June 4, 2022 Joe, it just hit me...is it really the adhesive still there? Like it's sticky? Or could it be the shadow left on old paint that wasn't exposed to light? 1 Quote Link to comment Share on other sites More sharing options...
XXitanium Posted June 4, 2022 Share Posted June 4, 2022 Light polishing cream and a clean cloth. Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted June 6, 2022 Author Share Posted June 6, 2022 I got some generic adhesive remover at work. It takes glue and some skin off, but not tattoos, so I figured its kindasorta safe, right? I haven't had a new vehicle in decades, so I'm kinda skittish about the little bit of finish that it has. It looked fine but got really hot. It's in a flood plain, though, so most everybody should get FEMA compensation, right? Who knew powdered aluminum would burn, y'know? I mean it's a metal, you'd think it would just melt. Oh well. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted June 6, 2022 Share Posted June 6, 2022 17 minutes ago, rockmeupto125 said: It takes glue and some skin off, but not tattoos, so I figured its kindasorta safe, right? You could test it on a hidden part of the tank. 21 minutes ago, rockmeupto125 said: It looked fine but got really hot. It's in a flood plain, though, so most everybody should get FEMA compensation, right? Who knew powdered aluminum would burn, y'know? I mean it's a metal, you'd think it would just melt. WTF? And lots of stuff will burn in powder form. The talk/baby powder stuff a pool hall used to use (for lubing your hand where the cue slides across your skin) they had it in plastic squirt bottles, get just the right amount to shoot over a cigarette lighter and you'd get a little fire blast. Quote Link to comment Share on other sites More sharing options...
tomek Posted June 6, 2022 Share Posted June 6, 2022 I predict 4 pages. 😁 1 Quote Link to comment Share on other sites More sharing options...
SwampNut Posted June 6, 2022 Share Posted June 6, 2022 2 hours ago, rockmeupto125 said: It takes glue and some skin off, but not tattoos, so I figured its kindasorta safe, right? You're kinda describing using acetone to remove cyanoacrylates or paint from your skin. I mean, that's nail polish remover, right? But certainly not paint safe. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted June 6, 2022 Share Posted June 6, 2022 ... as long as you don't get your cell phone dipped in it. Quote Link to comment Share on other sites More sharing options...
XXBirdSlapper Posted June 6, 2022 Share Posted June 6, 2022 WD-40. Really 1 Quote Link to comment Share on other sites More sharing options...
Biometrix Posted June 7, 2022 Share Posted June 7, 2022 WD-40 and if that doesn't work then Goo-Gone. If those don't work then a belt sander with 60 grit will surely get rid of it. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted June 7, 2022 Share Posted June 7, 2022 13 hours ago, Biometrix said: WD-40 and if that doesn't work then Goo-Gone. If those don't work then a belt sander with 60 grit will surely get rid of it. +1 But that goo gone gel really solves it for me every time, there's always a bottle around. Quote Link to comment Share on other sites More sharing options...
DBLXX Posted June 7, 2022 Share Posted June 7, 2022 Use your fingernail. Quote Link to comment Share on other sites More sharing options...
TOXXIC Posted June 8, 2022 Share Posted June 8, 2022 Mayonnaise. Pretty mild and the oils help break down the adhesives. Goo Gone and WD40 would be next on the list before Acetone or XYLOL. XYLOL is the terminator of all things adhesives. Dudes use it out here to strip all the factory graphic goo off their Razors. Hopefully Scott will chime in with a shop endorsement. Pretty far down my list as I wouldn't want to breath it....then again I spray Round Up around the houses multiple times per year. https://www.sunnysidecorp.com/product.php?p=t&b=s&n=822G1 Quote Link to comment Share on other sites More sharing options...
XXitanium Posted June 8, 2022 Share Posted June 8, 2022 ...love that stuff. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted June 8, 2022 Share Posted June 8, 2022 Xylene is a real motherfucker like MEK and shouldn't be used without protection and knowledge. I love what it does, and treat it with great respect. This shit is seriously effective though. Smells really great too, giving a false sense of not being a big deal. 2. Hazards Identification GHS Classification Health Acute Toxicity - See section 11 for specific toxicity. See section data on ingredients. Eye Irritation - Category 2 Skin Irritation - Category 3 Physical Flammability - Category 3 Quote Link to comment Share on other sites More sharing options...
