Everything posted by rhubarbray
Now it doesn't seem to work with either.
Edge seems to work, Chrome doesn't
I can't go forward or back in pages either. Will try another browser.
Was just browsing Kijiji ( like Craigslist ) and came across someone selling a pair of HeliBars. I have no affiliation nor do I know the person. Just thought someone might be looking for a set. https://www.kijiji.ca/v-motorcycle-parts-accessories/kingston-on/honda-cbr-1100xx-heli-bars-for-sale-175/1643118210?undefined
??? Photoshopped?? Tell me that's not real !
FZ1 for sale in PA
rhubarbray replied to rockmeupto125's topic in The Sales Floor -- For Sale/Wanted
That's the bike my buddy has that we've done two west coast-to-Ontario trips on. Last one was 9000km in 18 days. All back roads,...........well, except Kansas. No point taking back roads in Kansas, couldn't find a single curve. One thing he noticed was that his original red one got worse fuel economy than his newer anniversary one. Same bike, same ecu, same setup, different fuel economy. Weird. -
FZ1 for sale in PA
Actually Joe, have you ridden it? I thought you might like it. -
THIS!! ⬆️ I did the carbs on my V65 Sabre and those carbs are a SOAB to get in. As an experiment I soaked 1 for an hour, 1 for 4 hours, 1 overnight, and didn't do 1. I found not much difference between 4 hours and overnight and a bit of a difference between 1 hour and 4 hours. But a big difference between 1 hour and not at all. Given a choice, if I needed to get the job done I'd go for 4 hours. I also left them off for a week after the bath to see if they'd go rock hard again,..............nope, still soft. I also used Isopropyl Alcohol instead of Xylene. Way safer and we get it in 45 gallon drums at work. One thing I do not remember checking is if the rubber swells. Softens yes absolutely, but I can't remember if there's a dimensional change. We can get the oil here in Ontario at health food stores but it's a bit pricey, $20 for a small bottle. If you need to put a carb boot in a container and submerge it and you don't have enough, throw in some spare clean hardware, enough to raise the level of fluid to surround the part. Don't know who the original person was that found this out but thank you a hundred times over!!
Gee , you guys are more help than you realize. They haven't been back for more help so it must be fixed!
Brilliant strategy to seat a bead without a real compressor
rhubarbray replied to SwampNut's topic in The Garage
I remember reading this account of brake cleaner and flames. Thanks for reminding me! https://www.brewracingframes.com/safety-alert-brake-cleaner--phosgene-gas.html -
I'm going to make a recommendation of putting some of that clear self adhesive paint protection film at least on the front half of the fork legs. Should slow down the rock chips and keep the legs looking better longer.
Interesting. I know a bit about computers but usually enough to get myself in trouble. Why is it that on my pc I can see the schematic image but you can't?
I just copy/pasted the image, ignore the red crap. On the left hand side below where it says " blue tape " there is " crankcase breather tube "' Is that pinched where it comes out of the valve cover restricting air flow? This would cause a buildup of crankcase pressure.
In the second photo, you can see the white wires coming out of the red block then going into the black sheath. I would make sure that area inside the black sheath is absolutely clean then put some oil compatible sealant into the sheath sealing the wires. The sealant will probably have to be quite thin to flow into and around the wires. Perhaps something like this is available in Spain?
Was going to say a very Canadian blue 'bird colour! 😀
Gastank longterm use / ownership coated with Por-15
rhubarbray replied to XXitanium's topic in The Garage
There's quite a few others out there. Weirdly enough, some claim drying super hard gives it greater strength while others claim drying to a flexible film means it will never crack and peel. Which one is better? You decide. There are single component and multi component epoxies . https://www.dimecitycycles.com/red-kote-fuel-tank-sealer-liner.html https://www.caswellcanada.ca/epoxy-gas-tank-sealer.html https://www.aircraftspruce.ca/catalog/appages/gastanksealer.php?msclkid=af3911961a021df71bf34f5492c0a093&utm_source=bing&utm_medium=cpc&utm_campaign=TNT - Shopping - NB - Desktop&utm_term=4580153125315098&utm_content=All Products -
Torque adapters. sae https://www.amazon.com/Stanley-Proto-J5100-Torque-Adapter/dp/B001HWEAAG/ref=sr_1_1?dchild=1&keywords=torque+adapter+set&qid=1587329147&sr=8-1 metric https://www.amazon.com/Laser-7286-Torque-Adaptor/dp/B07K7GJ3FB/ref=sr_1_1?dchild=1&keywords=metric+torque+adapter+set&qid=1587329200&sr=8-1
Absolutely they're accurate but you just have to follow the rules when using them. You can use it straight out but you'll have to calculate how much less input torque you'll need as your moment arm will be longer. I have a near complete set of these for work and quite often there is nothing else that will fit in where you need to go.
Ha! Had to do this exact field repair on my FJ1200 in a hotel parking lot on a multi-week trip. Absolutely could not get the connector apart.
Make your own oring. https://www.mcmaster.com/o-ring-splicing-kits/ This is McMaster Carr but lots of other kits out there. Would this sealant work? https://www.permatex.com/products/gasketing/gasket-sealants/permatex-permashield-fuel-resistant-gasket-dressing-flange-sealant/
I'm just wondering out loud here but does anyone by chance know if a CBRXX engine will fit in a Honda 919 Hornet frame? 😁
Wasn't there a case of Suzuki setting the clearance too tight on their GSXR 750 ( I think ) in the mid 90's? Most people never knew but the ones who spent some time at redline had pistons kissing cyl head. Cost Suzuki a lot of labour and thicker head gaskets.
2003 XX with trailer, CraigsList find
rhubarbray replied to JJP XX's topic in The Sales Floor -- For Sale/Wanted
Now deleted
