aja
46 Neutral
About aja
  • Birthday 01/01/2006
    Yeti SB5, Cervelo R3
  • Website URL
    http://
  • ICQ
    BTV
3,911 profile views
  1. aja
    How to - Help
    If I'm understanding the situation correctly, you have two houses next to each other, one with a crappy well and the other with a good well which will provide enough water to both houses if you could connect the systems. If these houses really will be owned and sold together then the water systems could be connected by burying a section of ABS pipe and providing the correct valves etc. However, if there is even a chance the houses might be sold separately then I would avoid connecting these water systems as it will cause all sorts of headaches down the road for the different owners. Because of this I would suggest adding a storage system to the house with the crappy well so the cistern is slowly filling all the time but will allow for plenty of water when you need it. I installed systems like this in the past using a plastic tank which can be moved into the basement and which has a float valve to shut that water off when the system is full. The water in that system will be un-pressurized, so you woudl then need to add an additional pump and pressure tank to send water to your house. If you don't mind the noise this could be a centrifugal pump but we used a submersible pump with low pressure shutoff since it was silent, never needed to be primed and would not run dry. A benefit of this system woudl be you could also temporarily connect the good house to the storage system if that well ever ran completely dry and at least keep water in the house. Sounds complicated but it really isn't. Good luck and feel free to drop me a line with any questions.
  2. Well, Arizona IS in the South West! So I went ahead and placed my order from SW Moto, but in the process of digging around think I might have learned something more about this company which has been great for years, but has just gone through an ownership change. Hopefully this won't be a change for the worse... http://www.advrider.com/forums/showthread....4892&page=1
  3. I am looking for a set of PRII's also so if there is talk of another group buy this year, count me in...
  4. That's a great bike and I sold mine last year around this time for $3200. I posted it on this site: http://www.cbrforum.com/forumid_36/p_1/tmo.../smode_1/tt.htm and on the local craigslist. Got a number of hits within a couple of days of the ad's hitting and it sold quickly. Good luck and remember, timing is everything - coming into the best time of year to be selling a bike, at least in the frozen north...
