srideaux
  • Content count
    35
Community Reputation
4 Neutral
About srideaux
  • Birthday December 27
  • AIM
    72vettered@gmail.com
  • ICQ
    Plano TX
  • Interests
    2001 Blackbird ( red ) 72 Corvette Coupe, 2016 Tacoma TRD Sport......
    1976 CB400F, 1966 CB and CL 77
Enable
  1. srideaux
    Speedo Quit after Heavy Rain Ride
    I have used the Speedohealer product on three different bikes over the years including my 01 Bird. sense 2005 . I would look first at the VSS connector. Pull it apart, check it for corrosion. clean all electrical connectors with "channel changer cleaner" it comes in an aerosol can, I have not bought any in several years, but use to get it from Radio Shack, I would look at E-Bay for it now. Good Luck
  2. srideaux
    1985 Kawi GPZ550 crossthreaded oil filter
    From time to time i buy "used or non running" bikes as winter projects to resell or keep for my collection, If I had a color picture and knew the mileage, I might be interested on a as is basis, only thing is you are a long way from Dallas.
  3. srideaux
    Strut/Shock Replacement...Part Question
    Best ride quality and warranty( Bilsteins) can be bought seperatly or in sets. you will not be disipointed
  4. srideaux
    Is it OK to run Aviation Gas in my 2003 XX??
    There are no catalytic converters on that bike, so running it should improve throttle response especially at lower RPM, but be advised, there are no stabilizing additives in Aviation Fuel. add Ste-bil for long term storage only, in a full tank. at the beginning of your riding season, siphon off as much as possible and refill with regular unleaded ( it burns faster and hotter than premium pump gas) My 02. cents
  5. srideaux
    Stainless brake lines
    In my own experience, after about three hours out in the country your back and wrist may speak to you in a painful way, the Helibars may help this.
  6. srideaux
    I must agree, in 04 I parked the Bird and bought a Busa. just to see how the other side lived. I gave it a year and sold it. I found it heavy feeling in traffic, we never connected the way I did with the Bird, I am 5'10" with a 28" inseam, with less than $1000. in up grades, including lowering the bike I can get 10sec. 1/4 mile times ( I am heavy and Old) Thanks to a Power Commander, and about two hours on a Dynojet chassis Dyno. one tooth smaller on the primary, and a trick Exhaust.
  7. srideaux
    To be honest, I haven't even looked at a can of Brake Fluid in 5-7 years, I will read up on the Motul RBF 660.......not to old to learn.
  8. srideaux
    Paul do what works best for you, but in the beginning don't take anything apart you cannot put back.
  9. srideaux
    power commander
    these are the only ones I could find
  10. srideaux
    Forgive me gentleman, I was only sharing my personal experience and preferences with the LBC and synthetic Brake fluid, I am now 14 years into it with no regrets. I defer to your Expert opinion.
  11. srideaux
    Randy I agree most people like the LBS, personally I do not, I just feel I have better control in hard braking situations, I have never seen LBS in MotoGT or Superbike there is a reason for that. Anyway I am glade I caused some conversation. Good luck to you all
  12. srideaux
    Redbird....exactly the opposite is true, just because you read it on the internet does not make it so. spend more time on research
  13. srideaux
    OE brake lines deteriorate internally and Dot 3 draws moisture which create corrosion/oxidation which will accumulate at the the lowest point. There becomes internal Bypass, the clutch rod not getting full travel, remember these calipers are Aluminum they will corrode. look at the crap that first comes out when you begin to bleed the clutch line. DOT 3 bad....draws moisture creates problems DoT 5 Good........synthetic, much higher resistance to heat, does not accumulate moisture.
  14. srideaux
    Spiegler worked for me, about 10 years ago, replaced all rubber lines , I am 65 ( old School ) never trusted the LBS so I disabled it, I feel like I have better control over the bike now and yes definitely do the clutch line. after a thorough flush I recommend DOT 5 fluid I use a commercial vacuum device operated by compressed air. Gravity bleeding takes to long, and can leave air pockets. After 50 years, the brakes are no place to scrimp. Best of Luck
