brent
Everything posted by brent
  1. thanks, I didn't paint it the previous owner did. though i learned to like it
  2. thank you hank, I will let the buyer know ~Brent
  3. the cam gear wasn't loctite on, it fell off sitting at a light and shut off. my mechanic said it probably bent the valves
  4. sorry its been a while, here was the original post i believe boost + detonation caused the issue
  5. Hello All, its been a long time since I been on here, I have a 1998 turbo blackbird that I enjoyed for quite some time. I had an issue with the fuel pump that bent a valve, I had the motor dropped and the engine rebuilt lasted me a few months until the cam gear fell off..... since then its been sitting in my friends garage collecting dust which is a shame, life changes are forcing me to sell and hopefully find someone who enjoyed it as much as i did. these photos are when it was last running, the paint i am sure is scratched up and will need to be repainted from sitting in a garage. I will try and get some updated photos. I have put 20k+ into this bike, accepting a reasonable offer. Bike is located in Springfield MA Brent
  6. its odd, was still making plenty of boost just seemed to bogg down for a sec then the turbo would come on hard and blow the tire out.. and lots of smoke not from the tire
  7. how much? should be around 400hp @ 20lbs and pump gas..if i run race gas 35lbs should be over 550 but its completely pointless to run that much boost i get her this weekend she is finally someone complete...possibly a video too Have you reinforced you joints, or are you expecting them to pop every time you hit the gas? Instant wedgie JB Weld more problems, the turbo was blowing smoke like a fog machine... very embarrassing how much? should be around 400hp @ 20lbs and pump gas..if i run race gas 35lbs should be over 550 but its completely pointless to run that much boost i get her this weekend she is finally someone complete...possibly a video too Hmm.. Those are some pretty stout numbers you're posting. Which turbo did you end up using? 65mm hybrid And what cams/headwork have you had done? What RPM are you running to? Ill have to have redcam chime in on this one, Running to 13500 RPM IMG_0443.MOV IMG_0444.MOV
  8. Late to the party I know, but since somebody already resurrected it..... Isn't this the same XX that was in the International Motorcycle Show a couple years ago? if you are referring to the one at the javitz in 07 then yes
  9. how much? should be around 400hp @ 20lbs and pump gas..if i run race gas 35lbs should be over 550 but its completely pointless to run that much boost i get her this weekend she is finally someone complete...possibly a video too Hmm.. Those are some pretty stout numbers you're posting. Which turbo did you end up using? 65mm hybrid
  10. how much? should be around 400hp @ 20lbs and pump gas..if i run race gas 35lbs should be over 550 but its completely pointless to run that much boost i get her this weekend she is finally someone complete...possibly a video too
  11. ended up ordering from honda frickin 47 for that little sensor :icon_wall:
  12. I forgot to take unboxing pictures, Stan did an excellent job on the crate.. I was expecting some headache getting the engine back in since it was quite troublesome to take out.. but so far so good everything went smooth and im excited to see how much power she makes...
  13. The 97-98 were carbed and not FI your right...I just assumed because this came in a box of parts with my bike. Anyone know how to identify the year?
  14. Got a full electrical harness no ECU for a fuel injected XX any offers?
  15. Ill be posting pictures with the install this weekend, might not have a dyno till next year when it starts warming up again...but will see
  16. wow im in complete awe, excellent work stan! I cant wait to get her back together!
  17. i need a tail for my 97 bird anyone got one??>
  18. from a 97 black bird anyone want any of this stuff? need to pay my motor build
  19. 97 carbed i think it was FI at one point
  20. To get the rash out we are going to have to bore it, Brent. Oversize, pistons? no i think they are stock size, not 100% sure...maybe it would be cheaper to get a head off ebay or the board? what do you think?
  21. Stan found 2 je pistons and carillo rods, and a bunch of rings.. will be sending it out with a few other things this friday... also found a set of (i believe) stock hayabusa and blackbird pistons if anyone wants them
  22. Ahhh, so THAT'S who made the trigger for MSD. I often wondered about that.. The crank doesn't have the Falicon "Polished & Lightened" look so it was probably just balanced, journals chamferred & polished then sent back. Probably has the balancers removed too..or at least disengaged. (Best guess..) Brent: How is fuel managed? Stock ECU + PC3? If so, then there is no boost referenced compensation, so I'd picture a BEGI style FMU in there as well, which is fine for most street purposes. I wouldn't push it above 12 PSI, personally, simply because I have seen how erratic they can be after a little wear. Stan: How damaged/gouged are the crank journals? Honda has some pretty sizable bearings that may save a few dollars if it were just sent off for repair. If you're looking to make this setup bulletproof, now is the time to consider changes, btw. Fuel pump, injectors, and fuel controller would be high on my list.. Its carbed with a big fuel pump from a volvo, the computer is part of the dyna 2000 yes bgi fmu hopefully these pictures help
