sachimore
1 Neutral
    2019 Honda Grom
    Smyrna, TN
1,310 profile views
  1. Never have had them adjusted. Had an older guy that was Honda trained and worked at a dealership 20 years. Then opened his own shop and he talked me out of checking the valves. Eventually he moved away.
  2. 2002 Bird, during idle it misses and you can smell raw fuel coming out of the muffler. Above 1,500 RPM it's fine. 67K. Always garaged. Vacuum lines tight Almost New plugs No FI light Never adjusted valves Any ideas welcome Thanks Sach Smyrna, TN
  3. Can somebody tell me where the fuel pressure sensor is? I have a phone book sized tech manual and it's not listed in the index. Thanks Sach
  4. Plugs and filter all new 5K ago. Rebuilt the entire bike 3 years ago except for the engine and trans. Did not see any need to touch them. Some great thoughts here and will follow up. Thanks guys Sach
  5. Need some advice guys. Have a 2002 Silverbird with 65K on it, well maintained and has never had "any issue" of any kind. Garaged and loved for 20 years. Recently noticed that at idle it is no longer the smooth no move tach needle at 1,100 RPM. It bumps. Every few seconds it’s like one of the combustion cycles is a little stronger than the others and the needle can bump up a couple of hundred RPM and immediately drop. Then hit again and again. You can feel the bump in the seat. Few days ago I started to get a low RPM type burble when pulling away from a stop sign. A miss kinda. By 1,600 or 1,700 RPM smooth. The next day worse, the burble turned to a low RPM power loss as it leaned to actually cutting out. Smooth out moved to around 2,000. Next day worse in all directions but now I have an occasional feint back fire while the RPMs rise. But after 2,400 smooth as silk. Whatever it is it is happening fast. I’m a decent mechanic but not electrical which this feels like. Any ideas appreciated as I have no idea. Or at least where to start. Thanks Sach
  6. Found .com and posted there. Thanks. Man, you been around here a long time................
  7. I have one, not stock but after market. Don't ride two up anymore and think it looks better off.
  8. For sale is my 2002 Bird and I thought I would list it here before going to cycle trader. I've had this bike since 2003 and am the second owner. Bought it from a guy that put 1,200 miles on it and was selling it because, he was honest, he was scared of it. As was I once I rode it but I finally realized she was for me. I am selling it because my 67 year old knees just can't handle it any more and as I am now retired need something else to explore the US on. It has 64.5K easy miles on the clock and the engine and trans run like new and well maintained. I planned never to sell it so over the past 3 years I rebuilt everything with either OEM or upgraded after market parts. Some nonperishable parts go back further. Now when I say everything I mean what I say. I used to be an auto mech years ago so decided to do the number on this ole girl. Put several thousand dollars in parts on it and I have no idea how many hours. Only thing I think I missed was the clutch plunger seal, slave end. I am still putting the list together but the larger things are: Engine, plugs, air filter, new oil (every 2,500), new wheel bearings, new swing arm and bearings (old one had cosmetic damage), brake system 100% new including gaffer lines, HyperPro suspension 100% new - rebuilt original forks with new springs, oil and bushings, new gas rear shock - note here that between the new swing arm (old bad wore out) and this new suspension it rides better than new, full race Micron exhaust (got the last one), Helibar risers, Buell foot pegs (lower 1"), Corbin seat recently recovered by Corbin, Second Look marine grade leather tank cover (CBR XX) - tank has not a scratch on it, new clutch and brake levers, took everything off except engine and electrics and painted the exposed frame metallic black, tires are Michelin P4s with about 500 miles on them, wheels silver powder coated, hi tensile DID chain and sprockets - my 6th set and has about 500 on them, I've had 3 after market wind screens but put OEM back on it. I'm sure I am missing some things but if interested let me know and I can load you up with pictures and talk more about the subject. Gonna ask $6,000 but this bike is in righteous shape and ready to go many miles or make a great collector piece. I think soon the value will start to increase. Parts are getting expensive if you can find them. Also, the paint is not perfect, there are a few light scratches and scuffs on it that somebody that knows how could probably fix. Still looks very good though. Nostalgic being on this site again as I used to be here a lot and it saved me much money, pain and time. So thanks to all. Questions, fire away! Gary Maddox Smyrna, TN
