0 NeutralAbout Boov
- Birthday 10/17/1974
Gender
Jenison, MI
I replaced the rear brake pads on my '99, and the old ones had a couple of extra pieces of hardware attached to each of them. They look like one part is for anti-vibration, and the other is for air flow for cooling maybe. Should I keep those parts in there with the new pads? I got really basic, nothing special pads and I'm still using the stock rotor. Thanks
I'm an electrical engineer, and I'm doing some wiring "stuff". I don't have a schematic for '99 so could somebody look this up for me? I'm looking for 5-10amps of ignition switch controlled power. Is there that much available on any of the stock circuits, or am I going to have to install my own "ignition on" relay off of the fuel pump curcuit or something to make what I need? Thanks
If you want way too much information about display and mirros, here you go: I used to work for an auto supplier that made rear-view mirrors For the rearview mirror that has the compass and temperature (comp/temp) display we would start with a regular, full mirrored peice of glass. This is a peice of safety glass coated on the back side with silver, some other metal, and two layers of paint. We would then mask off all but the comp/temp window and sandblast the paint off the back side of the glass with a baking soda sandblaster. We then used a special acid compound to dissolve off the metal and silver to create a clear window where the display is going to go. The VFD (vacuum flourescent display) on the comp/temp circuit board lines up with the window. We also made the mirror that has the backup camera display built into it. I only ever saw this on a comercial once, but it's really cool. When the car goes into reverse a display turns on that is behind the mirror and displays through the reflective surface. When it's not on you can't tell that it's there. These mirrors have a special (thinner) silvering on them that a display can make it through. This type of silvering takes a zillion-dollar machine to apply properly using technology you've never heard of in a machine that looks like it belongs in NASA. Anybody ever heard of sputter-coating? Unfortunately, this is not a retro-fit you can do to a regular mirror.
This was my typical tightening strategy too, and maybe this wasn't entierly from being too tight. The first time I turned this nut after buying the bike was to replace the back tire. It took me 10 minutes to get it off, and I definitely rolled some of the threads out. I should have gotten a new axle then, but I'm way too dutch to but something before I absolutely need it. Typically you keep a fastener from galling by lubricating it. Would you dare to give the threads a drop of oil?
Years ago someone had told me that you couldn't get the rear axle nut too tight (within reason). In other words, the tighter the better. Well, I spun the threads out of mine, destroying the nut and the axle. So, I have two questions: What is the Honda torque spec? How tight do you put yours?
I'm all set. Sometimes I'm a little hesitant about an eBay seller shipping stuff in a timely manner, but this seller seems okay. Thanks.
I am in need of a replacement rear axle and nut for my '99 XX. I will give up in a day or two and order one from Honda, but they seem to think that these are made of gold. If anybody has a parts bike or just happens to be sitting on an extra one of these, and you wouldn't mind looking into next-day shipping for me, I would appreciate it. Thanks.
I have a craftsman lift. It is just a bottle jack connected to a linkage that lifts two horizontal bunks off the ground. It worked awesome for my Magna a couple years ago, mainly because I could get both tires off the ground and wheel it around in any direction on the casters once it's lifted. Now, this lift doesn't pick up my XX worth a crap. I'm thinking that I need spacer blocks, or adaptor brackets, or something so that I can lift this bike while keeping it centered and stable. Did anybody come up with anything? Can youu share drawings or pictures or anything? Thanks.
Heh, just asking.. And yes, you can tee right into the return line without any problems. Post up some pics of your finished product. I'm curious to see the final result. You have some good points above. Sweet, thanks. Since I'm in Michigan I have at least 4 months of down time in the winter to tinker with this sort of thing. I'm just doing the research now so I'm ready. I'll post up pictures when I'm done.
There are a couple of reasons I don't like gravity feed. First, I don't like manual valves, because they can get bumped, accidentally left on, and they are bulky. Plus the lines to and from the valve are exposed to damage, and the valve itself has to be mounted somewhere where it's accessible while driving. It doesn't seem like it's something I can do and make it look really sexy. Second, if I only tee into the return line than this setup can be 100% removed some day with no evidence. If I do ever sell the bike someday, I don't want to have to explain extra holes and brackets and stuff, I just want to bring it back to exactly stock. Besides, I'm an electrical engineer, so I really want to put some cool wiring farkles on it somewhere. So, back to the original question: can I tee into the fuel return line and pump gas into there without causing problems?
I was thinking that I want to pump from my aux tank to my main tank. I have a few different styles of small form factor, high pressure (fuel injection) car fuel pumps that I have been collecting for this project. What I'm hoping is that I can find a pump that doesn't allow the back-pressure of the return line to go backwards into the aux tank, and also have a low enough pump volume that it won't effect the bike while it's running. I had a setup kinda like this on my Magna and it worked really well. It sounds a little overly complicated, but I like it because I can hook the fuel pump switch to a ignition-controlled power source and nobody can mess with it. On my Magna I mounted the fuel pump under the seat towards the back, and it looks like there is room back there on a Bird too.
I want to add an external auxillary fuel cell to my '99 Bird. I don't want to modify the fuel tank at all to accept fuel from an ouside source. Can I tee into the fuel injection return line between the fuel pressure regulator and the tank? How much back pressure and flow is there during normal operation? Would it cause problems if my system added additional back pressure to the tank side of the FPR?
I put Roadsmarts on my 99. I have about 3k on them so far and I really like them. They're not half gone yet, and I like how they're not squaring off at all. I don't "push it" much so I don't know about their sport performance, but they are great in the rain. The tar snakes still give me a handful.
