Posts posted by blackhawkxx
1 hour ago, Furbird said:
The most aggravating thing about newer vehicles that I run across are passive locks. If you don't know, that means cars that lock by themselves.
Can it be turned off in the menu? I always turn off auto door lock that lock once the vehicle is moving.
1 hour ago, DaveK said:I also love that a lot of the HVAC settings are all based off of exactly how I want the car conditioned based off season, time of day and outside temp. I love that it detects moisture on a window and takes the appropriate action to cure that problem at the exact time it knows I get in to leave.
So much goodness in my newest car.
I love roll up windows and manual door locks. I keep things a long time and try to fix them myself. Different strokes for different folks.
If I were buying a new car every couple of years, my opinion may be different but maybe not.
- 1
7 hours ago, IcePrick said:
I'm sure most people don't know about the hidden key in their fob and the hidden keyhole on their car.
There are all sorts of little nuggets of wisdom in that 350+ page book in the glovebox. Since nobody ever reads it, they'll probably soon resort to putting a QR code sticker inside the glovebox and tell you to look it up online so they don't have to spend the money publishing it.
How many average folks know how to get their modern auto-transmission car into neutral without battery power? Can they find the towing eye for their car? How do you pour gas from a portable tank without a nozzle into those tricky new gas fillers? Just a wild-assed guess, but information of that sort might be in that manual, and reading it by flashlight (you DO have two of them charged and handy, right?) beside a busy highway while the sketchy-looking tow truck driver roots around in your car trying to figure it out himself probably isn't the best time.
I always look read through the manual but either missed the hidden key hole or it isn't in there. I already knew about the shifter lock out at least on Fords and Ford supplies a funnel with the vehicle for adding gas. I never step out of the house without my knife and flashlight plus 99% of the time, a weapon.
- 2
26 minutes ago, Furbird said:
It probably has a painted plastic cover on the driver door handle that you have to pop off to reveal the key hole if you don't see it. They've been doing that for several years. Of course, that means it will either break upon removal, you'll scratch it with your knife/screwdriver/method of prying it off the car, it goes flying and scratches it up when it hits the ground, or it will fall in the drain in the Walmart parking lot.
Well, after searching, you are correct. It sure is hidden well and I didn't notice it in the manual. BTW- Ford Fusion. Someone knows the answer to just about everything on here, thanks.
- 1
The battery in wife's car died and it got me to thinking, what if the battery completely died, how would you unlock the door to open the hood since it doesn't have key locks? I hate not having key locks for both the doors and truck.
Something as easy as changing the battery turned into a pain. Napa didn't have one and said they could have it the next day (their best AGM). Pulled the old one today, took it over in the Wing and the one they said would fit was too big. So they ordered a smaller one for tomorrow (don't make a AGM in that size). So back over tomorrow.
9 hours ago, superhawk996 said:
Love it.
I think the reason the first cut got buggered is because you were pushing on both sides. I think the cut gap closed right at the end 'pinching' the blade. I'm guessing that it pulled the part on the right into the blade a bit, or flexed the blade into it.
Yes, right at the end of the cut you can see the front edges come together.
10 hours ago, IcePrick said:
Seriously, try the cutting fluid I posted and some affordable bits first. I have some cheapie Black and Decker bits that a neighbor gave me when her son passed away, they cut much better with the correct lubrication and have lasted way longer than I thought they would. The guy at the welding store said "that stuff will change your life" when I brought the can to the counter, and after using it for a while, I think it is a major improvement in cutting. The Vortex bits are a big investment if you don't make lots of holes.
Sharpening is part art, part science - and difficult to master in my experience. There is no fool-proof tool that I'm aware of. I bought these bits to avoid having to go through the expense and frustration of the newest/latest/greatest sharpener and the learning curve, only to be disappointed again. I have a friend who is a master at it, but he's also a machinist so he has that gene.
I agree 100%. And yes, Tap Magic (the brand I use) changed my drilling life. My low cost way is when Harbor Freight has their OK bits on sale for $9.99, I grab a set, use a lot of lube and when they start to dull, buy another set. Of course I'm not a daily driller nor making anything high dollar so...
Great video.
5 hours ago, XXBirdSlapper said:
Still having problems with the site. Forward arrow won't work to view other pages.
Search won't work.
Hadn't been able to insert images, but currently working.
Can't imbed video
Have you tried different browsers?
1 hour ago, ironmike said:
Hmm, didn't see any pricing . . . Does one have to call?
Here is one place, out of my price range.
Vortex-Point Drill Bit 29 Piece Fractional Set Each Price: $232.61Each Price: $232.61 -
10 hours ago, SwampNut said:
Heat puts a lot of stress on clothes.
Then I guess my clothes should last 10X of yours.
12 hours ago, SwampNut said:
I need to get the fogger replaced, last night we lost half our whisky to gnats, but there were no mosquitos. Don't know why.
They prefer beer?
A reality check is good for all of us at times.
No matter how well someone can do something there is always someone that can do better. But saying that, other people is the reason I have always lifted at home.
Well I did my part in smashing some with the Bird and my face shield yesterday. Putting it away for the winter.
5 hours ago, SwampNut said:
We have an asian mosquito invasion that's super annoying.
I didn't think mosquitos would be a AZ problem being how they are usually a wet climate thing.
Thanks for the review. I hope that it doesn't apply to their tools as I have been sucked into buying more (7 I think). I do have their lawn mower for 2 years now and it has been flawless and haven't had any trouble so far with the rest. The price and the one battery is what drew me in.
2 hours ago, IcePrick said:
Unless one wants to experience the full charm of 1950's automotive technology and all of the bad that goes along with it, points are just an ugly memory. I can't imagine owning a points distributor that hasn't had a Pertronix Ignitor installed.
Maybe everyone is spoiled now? My 78 Subaru had points and every 10K I would check them plus the spark plugs would get swapped out often because of the leaded gas and being regular style but it only took a couple of minutes and really wasn't a hassle to me. With the old style ignition you could almost always get it to run at lest somewhat, with the new stuff, when it dies you ain't going anywhere. Saying all of that, yes the new stuff works better.
Edit to add: I just remembered my Falcon had a Accel race dual point that was good for 10,000 rpm and seemed to work well.
Maybe you improved the connection by removing them. Any type of corrosion at connection points?
3 hours ago, SwampNut said:
Now that's scary as I eat much natural peanut butter every day, it is a food group for me. I must have 15 jars in stock.
4 hours ago, fizzy said:They are called redskin peanuts, unsalted, come in a plastic bag.
That's the problem, the ones covered in salt kills the bad bugs. 😃
3 hours ago, CALCXX said:
I am new to air fry. I love it. I rarely use the frying pan anymore.
Thanks for the link. I think I need this.
https://smile.amazon.com/gp/product/B0764HS4SL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I'm kind of weird I guess because I enjoy using a knife to cut things up but I am a knife guy.
2 hours ago, CALCXX said:
I click yes and proceed. I can reply but I cannot click like, bullshit, crackhead, Award, upvote.
Something on my end ? Here's what I get ---- Sorry, there was a problem reacting to this content.
That happened on my phone the other day but have never happened on my computer which I use to view this site 99.5% of the time so I thought it was just a phone thing.
2 hours ago, Zero Knievel said:
Those photos ARE without the front straps.So if you shake the bike how does it feel? Does it feel it will hold it there?
If you unhooked your front straps maybe it will show you how the rear is doing?
Car door locks
Posted · Edited by blackhawkxx
A couple of months ago the wife was taking the car out of state to visit family and I worked to make sure she remembered those numbers.
It could make a difference.
