Posts posted by blackhawkxx
I'm wondering if I should buy one to have just in case.
It takes motivation to spend hours rubbing on metal. I start out motivated then it seems to go away. It's looking good.
After studying the pic with the tire in it, looks fine, nothing to worry about. 🤥🤥🤥
12 hours ago, jon haney said:
This builder knows what they are doing. That is the cleanest looking naked BB I have ever seen. Guessing that is a Busa front end.
I know beauty is in the eye and all that stuff but I'm not seeing that at all. I think Birds are way too good looking to screw up like that but each to his own.
Have you ever noticed it's the rabbit food eaters that want to rid the world of meat after they stopped eating it?
7 hours ago, XXitanium said:
Separate issue:
I'd rather have Hard Rock (low volume setting) with a beat than mindless static.
I hope that sleeping with white noise don't warp the brain because I do always.
51 minutes ago, jon haney said:
One size does not fit all. Genetics play a big role, as well.
This.
5 hours ago, SwampNut said:
I can't tell if you're trolling. Risk reduction and correlation don't work that way, but it is less likely. "Non-smokers shouldn't get lung cancer?"
I wasn't trolling but your headline-"how diabetes T2 is primarily an animal fat disease, not carbs" made it sound like my question. Yes I understand weight and diet has a huge effect on diabetes.
So vegetarians should NOT get diabetes?
5 hours ago, CALCXX said:
Made me eat pizza and drink beer for two days waiting for the part.
Man the sounds rough. 😃
- 1
- 1
Have you tried aluminum foil and pop?
It's hard not to get the swirls. I had something marked down on a computer sticky note that was said to work well and all my sticky notes disappeared one day. ☹️
6 hours ago, rockmeupto125 said:
You could have borrowed my one inch railroad gun. It uses a ton of air, but has removed every fastener I've put it on.
What's it take, three men and a boy to pick it up? 😃
- 1
I noticed last year watching NHRA drag races that some of the top teams are still using air powered tools to tear down the engine between rounds which is a time sensitive deal. Must be a reason.
I'd like to hear someone explain that.
5 hours ago, superhawk996 said:
Just to be clear; the gasket didn't start out brittle, it became brittle in use.
By starting out, I meant the start of this experiment.
Has anyone here ever used lights like these? They seem too cheap.
13 hours ago, TOXXIC said:
My wife does a similar mix of pre chopped Ingredients mixed in the meat…however, the process does not seem like a common thing here.
Since someone can't grill a burger without technology (🙂), let's see your wife's. 😀
- 2
- 1
3 hours ago, fizzy said:
Covered with red rubber grease
Is that silicone grease?
Maybe if it starts out brittle it stays brittle? I'm guessing the material difference is the difference.
1 hour ago, tomek said:
And one set would be beautiful and shiny, the second one, from bare wheel balancing-dull and flat.
I usually paint them to match the wheel color so they are less noticeable.
and it's possible that their wheels and tires are more perfect than what we buy.
Which makes me wonder, is there any point to balancing the bare wheel first which would be a permanent balance?
22 hours ago, SwampNut said:
@OMG?
https://www.cycletrader.com/listing/2003-Honda-CBR+1100XX-5030300944
Nice machine, first one I've seen in a long time that probably should command a high asking price.
That is nice! I wonder why the steering head bearing change at 16K?
Fuel leak on my 97 XX
Just the first place I pulled up.
https://www.hondaparts-direct.com/oempartfinder?aribrand=HOM&arian=motorcycle#/Honda_Powersports/CBR1100XXA_(97)_MOTORCYCLE%2c_JPN%2c_VIN%23_JH2SC350-VM000001_TO_JH2SC350-VM002696/FUEL_TANK_97-98/a8a32a84-8362-4005-954d-63558f8eb2d1/6bb4be06-0493-43de-9236-6a0ee959d5e7/y
