We're up and running and stronger than ever! In a nutshell, when I went to remove the plug from the number 1 cylinder (left to right) I noticed it was only hand tight. The remaining three were just over hand tight, maybe 1 ft./lb. of torque. :?: Unbelievable!!!! :evil: Who ever installed these should look for another profession. Needless to say the 1# plug was fouled and barely emitting a spark at all, not to mention the compression loss it was experiencing. All plugs have been replaced with new ones. Also, the 1# carb bowl had small amounts of debrise as well, I'm sure due to the lack of proper fuel flow rate. Remaining 3 bowls checked out clean. Also gave it a fresh oil and filter change just in case some raw fuel got by the rings in the non-firing cylinder. I will, however still run the BG-44K through it just to clean everything else out. I would like to thank everyone for their input.
THE BEAST IS BACK!!!! :grin:
